View Poll Results: What is your battery experience with Oreo on the S8?
Voters
14. You may not vote on this poll
  • Oreo battery life is as good or better than Nougat
    4 28.57%
  • Oreo Battery life was worse, but I made it match Nougat
    1 7.14%
  • Oreo battery life is worse, and I can't fix it
    9 64.29%
  1. Robert Romero2's Avatar
    I've been reading posts in a number of forums about the worse battery life with Oreo on the S8. I'd like to do a poll.
    04-11-2018 05:08 PM
  2. THEPRFCT10's Avatar
    Much worse. Sadly.
    04-11-2018 10:36 PM
  3. mmcclure0453's Avatar
    Mine has been little to no change on Oreo. If anything, I believe it's a little better. Definitely not worse.
    04-11-2018 10:45 PM
  4. koves's Avatar
    I've been getting roughly 5 hours SOT once I've hit 15%. it's a little bit better for me
    04-11-2018 10:58 PM
  5. badcat's Avatar
    Fine on my S8+. I did a reset after updating though and have zero issues.
    04-12-2018 06:13 AM
  6. Tcbemis's Avatar
    Not much difference after doing a factory reset, but my battery was before that, so...
    badcat likes this.
    04-12-2018 07:17 PM
  7. Dirtymike14's Avatar
    horrible battery life for me, but I have yet to try a reset after updating it
    Vylet22 likes this.
    05-03-2018 02:06 PM
  8. sarra1833's Avatar
    My s8 is 4 days old and my God, a full battery goes to 30% within 3 hours. Display is lowest setting, power is set to normal (not gamer or performance), screen shut off is the lowest. Literally every thing is set to minimum and I'm not running graphic intense things at all.... This is a typical Android for me sadly. Batteries last between 3 hrs and sometimes as disgustingly fast as 100 to 20 in 45 minutes.
    Also One to two bars of 3g if I'm lucky, but that happens to me even when I'm in a huge city, no matter the phone.
    05-05-2018 02:13 PM
  9. BB_PP's Avatar
    just reset it!
    mmcclure0453 likes this.
    05-05-2018 02:53 PM
  10. AmyC76's Avatar
    Reset and still crap. In 2 hours I've gone from 91% to 78%. I've not been on it but maybe a few minutes from time to time. I give up lol
    Vylet22 likes this.
    05-05-2018 03:59 PM
  11. adegbenroagoro's Avatar
    Hi. Are you Supergirl in disguise?!
    05-07-2018 12:22 PM
  12. BB_PP's Avatar
    wait day or two. let OS settle
    badcat likes this.
    05-07-2018 12:32 PM
  13. chileboy's Avatar
    I believe mine is improved somewhat tbh
    05-07-2018 12:43 PM
  14. Alan Sims's Avatar
    I agree very bad
    05-07-2018 07:25 PM
  15. Feldhege's Avatar
    Mine has not improved either. Wiped cache and didn't seem to make a difference. I will try a reset when I get time. In the meantime, I have a battery case on it.
    Wish google would let GSAM monitor individual apps so that I could see what is actually killing it.
    Robb
    05-09-2018 02:38 PM
  16. Eneal92's Avatar
    I've had terrible battery life since I updated to Oreo as well. Here's a screenshot of my battery today. I've barely used the phone and it's dropped over 55%. The Android system has consumed 97% of the power used since I took it off the charger this morning. Before Oreo the battery wouldn't have drained anything like this from just being idle. Oreo battery life-smartselect_20180511-145811_settings.jpg
    Vylet22 likes this.
    05-11-2018 03:02 PM
  17. badcat's Avatar
    Look to see if you are having any sync issues. I had this problem once when for whatever reason my Google Contacts just wouldn't sync and the phone just kept trying and ran down the battery.
    I disabled contact sync and the issue went away. The weird thing was I could sync manually but auto-sync would hang.
    Worth taking a look at.
    05-13-2018 08:08 AM
  18. BB_PP's Avatar
    Check here! reset it and see the difference.
    05-15-2018 05:38 PM
  1. Note 8 notification panel doesn't slide down completely after Android Oreo update
    By Android Central Question in forum Samsung Galaxy Note 8
    Last Post: 05-19-2018, 05:29 PM
  2. horrible battery
    By Jaj4e in forum Moto Z Force
    Last Post: 04-30-2018, 07:49 PM
  3. Replies: 2
    Last Post: 04-11-2018, 06:57 PM
  4. z force battery drain, shutting off,
    Last Post: 04-11-2018, 05:36 PM
  5. z force battery drain, shutting off,
    By Jaj4e in forum Ask a Question
    Last Post: 04-11-2018, 11:54 AM
