1. Virginia Smith42's Avatar
    Since update to oreo 2 days ago. I cannot connect printer to system. I can print test page from printer app, but that is all. Tried thru system controls and printer search.
    04-18-2018 11:34 AM
  2. Rukbat's Avatar
    Try using Cloud Print. (You'll have to set it up to use your particular printer.) Share the item you want to print. Choose Cloud Print to share it with. It should print.
    04-18-2018 12:46 PM
  3. Virginia Smith42's Avatar
    thanks, but found problem..Oreo, in connections, had knocked my HP printer off and replaced it w default. search the could not find mine. Also would not allow me to enter IP or host address manually. When I got rid of the default, mine popped up and all was well. Samsung help was of no help via email.
    04-20-2018 07:49 PM
  1. HTC 10 battery drain issue after Oreo update
    By Android Central Question in forum HTC 10
    Last Post: 10-17-2018, 12:10 PM
  2. Front Camera after Oreo Update
    By omalek in forum LG V30
    Last Post: 05-15-2018, 08:45 PM
  3. Keypad problem
    Last Post: 04-18-2018, 05:48 PM
  4. OREO 8.0 for All UK Models Thread
    By NightOrchid in forum HTC U Ultra
    Last Post: 04-18-2018, 10:52 AM
  5. Wifi connection problems lg g6 at public wifi sites
    Last Post: 04-18-2018, 02:25 AM
