Depends on the case. Most will not interfere unless made of really thick plastic or having interfering compounds in the material. It will also depend on the wireless charger you want to use: not all are as powerful or lenient when it comes to cases.
It would help if you share which case you're using and any chargers you have your mind on. I've tried with my Samsung chargers, a Seneo base, and my Prius' charging pad and they all work with any case I've used EXCEPT one that had a metal plate smack on top of the wireless coil.
04-25-2018 05:29 PM
