1. deadbeatles's Avatar
    Since my phone updated to Oreo a while back, there are a few updates that are terrible. For one, app icons look too uniform now, but who cares. Another thing is that long pressing an app icon will no longer allow you to go straight to the settings for that app. Now you have to go to Settings>Applications and scroll to find the app settings you want to change.
    But really the most annoying thing is the notification about an app using the battery. I get the notification all the time now and it will stupidly tell me that the app I'm currently using is using the battery. Well, no duh. Thanks for the news flash.
    The whole point of that notification is to tell you about an app that's draining an unnecessary amount of battery while running in the background. So, I would still like to be able to be notified of that when it happens, meaning I don't want to entirely disable the notification.
    Is there a way to tell this notification to dial it back a bit? Otherwise I'll have to disable it entirely, which I'd rather not do.
    05-01-2018 03:26 PM
  2. SpookDroid's Avatar
    Unfortunately that feature is an all or nothing kinda deal. All you can do is activate or deactivate three types of notifications (battery drain, put to sleep, and unstable app) but that's it. No way to dial in the drain level or per-app setting.
    05-01-2018 06:26 PM
  1. Anyone using a Vodafone UK M10P, Help
    By NightOrchid in forum Huawei Mate 10 & Mate 10 Pro
    Last Post: 05-02-2018, 08:31 AM
  2. My nav bar is doubled. How can I get rid of the second one?
    Last Post: 05-01-2018, 06:34 PM
  3. An app is not connecting to the internet althought there is a stable connection
    Last Post: 05-01-2018, 03:42 PM
  4. How do I get my contacts back from ICQ Agent?
    Last Post: 05-01-2018, 02:09 PM
  5. What's skms agent used for
    Last Post: 05-01-2018, 02:08 PM
