    So I left my charger at home but my friend brought hers. I wondered if you can charge an galaxy s8 with an LG phone charger.
    05-19-2018 09:51 AM
  2. Rukbat's Avatar
    It will fit. It will charge. It may not charge as quickly as you';re used to. (The S8 has Qualcom Quick Charge 2.0, the LG charger may not have any form of quick or rapid charging - but that's fine. You can charge a battery too fast, you can't charge it too slow. As long as it charges, it's "fast enough" to eventually reach 80% [which is the highest you should charge it to - 30% is the lowest you should let it drop to - outside those limits kills the battery faster].)
    05-19-2018 03:52 PM
  3. shadowsjc's Avatar
    the brand of the charger doesn't matter. what matters is the type of charger it is. The Galaxy S8 uses USB 3.0. The tip of the charger that goes into the phone is a rectangle.
    Some older phones use what is called USB 2.0. The charger tip is a different shape (it is closer to a trapezoid, not a rectangle), so it won't physically fit into your port (don't try to force it in).
    You should be able to tell from looking at the tip of the charger whether it's USB 2.0 or USB 3.0
    05-21-2018 11:11 AM
  1. How to unhide my applock in vivo y21l?
    Last Post: 05-21-2018, 11:18 AM
  2. Sharing My Experience With The Nokia 7 Plus
    By Alex_Hong in forum Nokia 7 Plus
    Last Post: 05-20-2018, 09:20 PM
  3. Can I leave my earphones plugged in the headphone jack? .
    By AndroidFan128 in forum General Help and How To
    Last Post: 05-20-2018, 07:56 AM
  4. I lost my text widget
    Last Post: 05-19-2018, 03:54 PM
  5. Linking android phone calendar to windows 10 calendar
    Last Post: 05-19-2018, 09:40 AM
