1. Rick Jacobs's Avatar
    Not only has my Smart Lock 'Trusted places' stopped working (I work from home it used to work), but Trusted places is no longer listed on the Smart Lock menu. I have On-body, Trusted devices, and Voice match, Trusted places is gone. I have no idea when this disappeard but I know it was there after my Sprint upgrade to Oreo.
    05-23-2018 02:12 PM
  2. Tcbemis's Avatar
    I guess that's why it's, stopped working then. Bummer. It was a handy feature.
    05-23-2018 02:17 PM
  3. Tcbemis's Avatar
    Actually... I just looked and it's still in my settings. But rarely works since Oreo.
    05-23-2018 02:19 PM
  4. Rick Jacobs's Avatar
    Just found this
    Trusted Places seems to have been removed as a Smart Lock option
    https://www.androidpolice.com/2018/0...t-lock-option/
    05-23-2018 02:26 PM
  5. Almeuit's Avatar
    That is why it stopped working -- because it is gone.
    It is happening across multiple devices. It is gone from Pixel/Pixel 2 Devices as well.
    Laura Knotek likes this.
    05-23-2018 02:50 PM
  6. TFBisquit's Avatar
    Well you know, if it's stolen at a "trusted" place, the thief can return and overtake your device. So from a security point of view it makes sense to me.
    05-23-2018 03:11 PM
  7. Ecm's Avatar
    Trusted Places is still available on my unlocked S8+ running Oreo.
    05-23-2018 03:35 PM
  8. maf113's Avatar
    just wait. Google will get to you soon enough.
    05-23-2018 06:00 PM
  9. Bob31464's Avatar
    I was wondering today what happened to it and when. I didn't wear my smart watch (trusted device) so I figured trusted places would work at work and that's when I noticed it.
    05-23-2018 06:39 PM
  10. sitlet's Avatar
    That's the point, you're only supposed to use it at a place you trust. I pretty much only have mine set to my house and a few friend's houses.
    05-23-2018 11:16 PM
  11. Rick Jacobs's Avatar
    Trusted places is back in the Smart lock menu and seems to be working.
    05-24-2018 09:12 AM
  12. Ten Four's Avatar
    Yes, it is back! The question now is does it work properly? Never worked well before for me. Time will tell.
    05-24-2018 07:02 PM
  13. Rick Jacobs's Avatar
    ***update*** I'm back to entering my pin every time I open my phone, this so sucks.
    I work from home, every time I used my phone yesterday Trusted places worked exactly as it should. Today I've had to enter my pin 3 times but after I opened Smart lock to check the Trusted places settings I have not had to enter my pin.
    05-25-2018 08:51 AM
  14. TFBisquit's Avatar
    It's here alright, along with the may update. And after setting and a reboot all options work properly.
    I do have to move the map a little bit though since my phone doesn't detect my location at the exact spot I'm in.
    The Netherlands.
    05-26-2018 04:53 AM
  15. Ten Four's Avatar
    It's inconsistent still. I just came home and it wasn't unlocked on the first try. However, after I unlocked it once, it has remained unlocked for awhile. That's better than before, if it continues to work this way.
    05-30-2018 08:53 PM
  16. Ten Four's Avatar
    UPDATE, July 27. On my Pixel 2 I switch the location setting to "Device only" for use with a nautical charting program, because I noticed that when on the water the location wanders all over the place when using "High accuracy." The full description for "Device only" is "Use GPS and device sensors to determine location." This also seems to have resulted in Smart Lock keeping my phone unlocked while at my home, at least for now! Will keep testing.
    07-27-2018 05:45 PM
  1. Gear S3 Frontier does not have lock screen option.
    By Android Central Question in forum Samsung Gear S3
    Last Post: 05-28-2018, 10:00 AM
  2. Replies: 5
    Last Post: 05-27-2018, 09:42 AM
  3. bypassing lock screen of a zte max 3 without having the sims card?
    Last Post: 05-23-2018, 12:52 PM
  4. How can I lock screen when answering phone calls?
    By hkkc in forum Ask a Question
    Last Post: 05-23-2018, 12:06 PM
  5. LG G7 Smart case
    By Android Central Question in forum LG G7 ThinQ
    Last Post: 05-23-2018, 11:34 AM
