1. justnivek's Avatar
    Hey guys I need your help
    my phone was working fine with VoLTE and recently I noticed I cant use data while on a phone call like I could before and now the option is completely missing
    Any help at all would be appreciated
    (idk if this has anything to do with it but could it be because of this? https://forums.androidcentral.com/sa...s-verizon.html)
    05-29-2018 10:48 PM
  2. justnivek's Avatar
    Just called Verizon and they said they was refreshing my account this was a little over a half hour ago now the phone completely stopped working no phone calls no data no texting I really need my phone for work tomorrow any help would be appreciated
    05-29-2018 11:35 PM
  3. justnivek's Avatar
    After hours and hours of research I finally just went to a Verizon store they couldn't help either called back to customer service technical support and after another hour on the phone they finally fixed it
    I hate phones lmao
    anon(123856) likes this.
    05-30-2018 11:23 AM
  4. Mattsg430's Avatar
    The usual fix is to go into settings/connections/mobile networks, and set it to lte/cdma. volte doesn't work when it's set to global as the mobile network (global is default I believe).
    05-30-2018 07:01 PM
  1. Replies: 1
    Last Post: 05-29-2018, 09:16 PM
  2. help me now!
    Last Post: 05-29-2018, 06:39 PM
  3. Can you help me get my default icon clock back?
    By 12ray_1992 in forum Android Apps
    Last Post: 05-29-2018, 05:41 PM
  4. quick setting missing in axon 7 ZTE
    By Android Central Question in forum Axon 7 & Axon 7 mini
    Last Post: 05-29-2018, 04:04 PM
  5. quick setting missing in axon 7 ZTE
