1. newtda513's Avatar
    When making calls or receiving calls I can not hear the other person on the line.
    If connect to Bluetooth or put the call on speaker phone I can hear them just fine.
    I have checked all settings in which are set correctly for volume.
    06-07-2018 09:47 AM
  2. B. Diddy's Avatar
    The earpiece speaker could be blocked (e.g., by lint clogging the speaker opening), or it could be faulty. Does this happen in Safe Mode as well? https://support.t-mobile.com/docs/DOC-34283
    06-07-2018 09:50 AM
  3. newtda513's Avatar
    I have blown out the earpeice and tested in safe mode still the volume.
    06-07-2018 10:24 AM
  4. B. Diddy's Avatar
    In that case, the earpiece speaker is probably faulty.
    Are you able to test calls using other VoIP apps, like Skype or Hangouts Dialer?
    06-07-2018 11:38 AM
  1. Phone volume keeps changing by itself
    Last Post: 08-10-2018, 05:01 PM
  2. Low quality camera v30
    By Crispdroid in forum LG V30
    Last Post: 06-11-2018, 11:13 AM
  3. Replies: 4
    Last Post: 06-09-2018, 03:12 AM
  4. Screen gets locked soon after the call starts in moto G5 plus.
    Last Post: 06-07-2018, 10:59 AM
  5. how to disable double tap to unlock while calling in samsung trend mobile
    Last Post: 06-07-2018, 10:25 AM
