Any solution?
  • Thread starter Android Central Question
  • Start date
A
I dont know what happened to my s8 plus. All of sudden it started making distorted sound while making calls, playing music etc. I simple restart would fix the problem and the problem comes back again after some time. I found out that if i eject the sim tray, the problem would be gone. I used it like for hours without the sim tray the distortion problem wont come. But as soon as i kept the sim tray, the problem came back again. Any idea?
muejnkfabet
