    On my s8+ my data won't turn off while connected to wifi. It's not the setting to switch to maintain a stable connection and its not the developer option either. Any ideas
    07-08-2018 12:34 AM
  2. joesf's Avatar
    Do you have the latest version of the Amazon Alexa app installed? If so it could be that. I had the the same problem and it turned out to be Alexa. Force closing Alexa app solves it.
    07-08-2018 10:33 AM
  3. E18iffy's Avatar
    That was it thank you
    07-08-2018 08:01 PM
  1. Why can't I find ultra power saving option on my infinix hot 5/559
    Last Post: 07-12-2018, 09:00 AM
  2. Disable fully charged battery on a Galaxy Note 5
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 07-09-2018, 04:55 PM
  3. Wifi Teathering Widget
    Last Post: 07-08-2018, 08:32 AM
  4. Home key turning phone on in my pocket.
    By japark in forum Samsung Galaxy Note 8
    Last Post: 07-07-2018, 06:27 PM
  5. Replies: 4
    Last Post: 07-07-2018, 05:24 PM
