1. delta7's Avatar
    Battery drains and takes pretty long to charge. What can I do to temporarily fix this? I wanna keep this phone for another year.
    07-12-2018 04:36 PM
  2. B. Diddy's Avatar
    It's unlikely that it's a calibration problem. The battery might just be failing or defective. Does it heat up a lot when charging? Do you routinely use the phone until the battery is down to zero before recharging? Routine deep discharges of a battery can shorten its lifespan significantly.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    07-14-2018 01:54 PM
  1. Replies: 1
    Last Post: 07-17-2018, 02:40 AM
  2. My web browser on my Samsung Galaxy j7 keeps crashing. What do I do to fix this
    Last Post: 07-12-2018, 06:35 PM
  3. Is it possible to add more file types in messages in Android messages?
    Last Post: 07-12-2018, 05:23 PM
  4. Shield K1 battery drain; is this normal
    By mattdeezly in forum General Help and How To
    Last Post: 07-12-2018, 05:06 PM
  5. clock on lock screen
    Last Post: 07-12-2018, 04:40 PM
