    I bought an galaxy S8 yesterday and bought a tempered glass with it too from the store. After coming home I found it very difficult to type from the right side of the screen ( o p l m). Is it my tempered glass or is it a manufacturing defect. I am finding it difficult to remove my tempered glass and check because it is a costly one
    08-03-2018 11:54 PM
  2. SpookDroid's Avatar
    Unfortunately unless you try it out without the glass it's really hard to tell which is the culprit. But in most cases, it is the tempered glass not being a quality one or not being properly installed that can result in bad input sensitivity on different spots of the screen.
    08-04-2018 10:54 AM
  3. djm1947's Avatar
    Assuming the store I stalled the screen protector, bring it back to the store and have them check it out. Most screen protectors come with a warranty
    08-04-2018 05:40 PM
  1. How do I add two of the same widget?
    Last Post: 08-04-2018, 11:16 AM
  2. Why won't my app store work at all?
    Last Post: 08-03-2018, 11:11 PM
  3. Trying to retrieve an album in my Gallery that is not in my Trash
    Last Post: 08-03-2018, 11:03 PM
  4. My media sound wont work on my galaxy j7 V
    By Schmidyboy38 in forum Samsung Galaxy S7
    Last Post: 08-03-2018, 10:42 PM
