1. William Lait's Avatar
    My 'selfie' camera on my galaxy S8 doesn't work, so when I open the camera app it closes shortly after - as it is stuck in selfie mode. Is there anyway I can start the camera in rear view?
    09-29-2018 07:49 AM
  2. Rukbat's Avatar
    That's the default, so it may be that the app is bad. Try installing a different camera app.
    09-29-2018 03:01 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Is this the stock Camera app you're using? The default for the stock Camera app should be the rear-facing camera, not the front-facing one.
    09-29-2018 08:54 PM
  1. Replies: 4
    Last Post: 03-04-2021, 09:56 PM
  2. P20, Why do I need to set up password to change launchers?
    Last Post: 11-07-2018, 08:44 AM
  3. Phone on flat surface needs multi presses to get a response.
    By Android Central Question in forum LG G6
    Last Post: 10-17-2018, 03:01 PM
  4. Replies: 5
    Last Post: 10-02-2018, 07:11 AM
  5. my private mode reset
    Last Post: 09-29-2018, 07:56 AM
