    This morning I tried to install custom recovery, but my phone wouldn't start up after the installation had been completed. I decided, stupidly enough, to completely wipe the phone, which resulted in my phone not working at all anymore, as there is no os installed. I searched up on internet what could I do and I found out that I should be able to install a stock rom via Odin. However, when I try to do that, I get an error message called sboot.bin. While trying to fix that, all of a sudden my computer told me the connection to my phone was lost, which resulted in the following situation:
    --- I have no OS installed on my samsung s8
    --- Odin doesn't work as I get error message sboot.bin
    --- My computer says it can't connect to my phone
    --- I'm able to get in to download mode
    If anyone knows anything that could possible help me further, words can not describe how thankful I would be.
    11-11-2018 07:57 AM
  2. Rukbat's Avatar
    It has to go into a repair shop that can JTAG it or has some other way to get firmware into a formatted phone. You wiped everything - including "Odin mode".
    11-11-2018 11:26 AM
  1. Why cant i access my mobile network?
    Last Post: 11-11-2018, 04:08 PM
  2. No notification bar, home button and recent apps not working
    Last Post: 11-11-2018, 01:41 PM
  3. Why does my update happen without my permission. Samsung Galaxy S 9 ATT
    Last Post: 11-11-2018, 11:03 AM
  4. What is the best method to transfer data to new pixel 3? The cable provided?
    Last Post: 11-11-2018, 08:40 AM
  5. Replies: 1
    Last Post: 11-11-2018, 06:34 AM
