1. sherloc987's Avatar
    Dear all,
    I am getting serious issue in WIFI since I upgraded to Oreo. Frequently the WIFI shows limited connectivity. This problem started after I upgraded to Oreo. Is there any solution? or Is there any way to go back to Nougat.
    Thanks in advance.
    https://wanderviews.net/best-front-and-rear-dash-cams/
    https://techranc.com/1337x-proxy/
    https://www.techlinc.in/free-netflix-cookies/
    https://www.techavy.com/kickass-proxy-kat-unblocked
    12-06-2018 04:50 AM
  2. methodman89's Avatar
    Since it occurred after the update, perform the following.
    Forget the wifi network from the phone. Reboot both the modem and wireless router. Clear your cache and reboot. Scan for new wifi. Discover and connect to the old one that gave you the problem. Good luck.
    12-06-2018 06:54 AM
  1. Is anyone else having sound issues?
    By Beansr519 in forum Samsung Galaxy Note 9
    Last Post: 12-10-2018, 01:45 PM
  2. My S8+ keeps waking automatically
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 12-09-2018, 10:02 PM
  3. App Issues - SD Card
    Last Post: 12-05-2018, 08:05 PM
  4. Public Wifi Android security question
    By walker7366 in forum Ask a Question
    Last Post: 12-05-2018, 05:33 PM
  5. My S8+ keeps waking automatically
    Last Post: 12-05-2018, 04:48 PM
