    When I connect flash drive using the attached type c connector to Samsung 8, I do get a drop down menu with choices to transfer files or photos but the response when tapped is always- usb disconnected...then... usb connected... then nothing and I have to start all over again. Suggestions? The device works on my laptop but not my phone.
    01-04-2019 11:35 AM
  2. belodion's Avatar
    I can only guess that you mean S8 rather than Note 8. Moved there.
    01-04-2019 12:59 PM
  3. Rukbat's Avatar
    A flash drive isn't a computer - you need a Type C OTG adapter plugged into the phone, then plug the flash drive into that. Then you shoulkd get something dropping down on the screen, probably My Files in a Samsung phone.
    01-04-2019 05:05 PM
  1. how to keep screen on during phone calls on note 8s
    Last Post: 01-04-2019, 05:11 PM
  2. How to use imperial measuments when logging food, Samsung Health
    By IronBob in forum General Help and How To
    Last Post: 01-04-2019, 02:35 PM
  3. I also need to get that number
    Last Post: 01-04-2019, 02:34 PM
  4. My S8 Active says fast charging but a second later it changes to normal charging
    By Android Central Question in forum Samsung Galaxy S8 Active
    Last Post: 01-04-2019, 02:18 PM
  5. Have no sound when I try to play video
    Last Post: 01-04-2019, 01:01 PM
