    Thank you all; going crazy here.
    SMG950U
    Software version:G950USQS5CSB1
    S8 works at home (Switzerland), but get "Not registered on network" anywhere else.
    If I get a local SIM in other countries, it works, so the problem seems to be in roaming mode only. If I move the Swiss SIM to another phone, even a very old one, it works, too. I then suspect the problem is the phone.
    Important: I used to live in New York, and I bought the phone from a US provider. The phone is unlocked (works in Switzerland with Swiss SIM). I mention this in case it helps.
    My take is the phone is not working in roaming mode, but it used to when I had the US SIM.
    I've searched the web, and I've done everything I've found: pull out SIM, reset networks, etc. I have even got a new SIM (in case the other one was faulty), and I've even performed a factory reset.
    I'm desperate :-)
    I'll appreciate any help I can get.
    lg
    03-17-2019 01:15 AM
  1. Battery drains fast on Samasung Galaxy S4
    By Captain_android in forum Samsung Galaxy S4
    Last Post: 03-17-2019, 10:43 AM
  2. Can I install recovery rom from SD Card via download mode on samsung device?
    Last Post: 03-17-2019, 09:36 AM
  3. I have a network lock on my lg harmony. Will rooting my phone get it unlocked
    Last Post: 03-17-2019, 12:36 AM
  4. When i am trying to send a pic in messages its not connecting to internet
    Last Post: 03-16-2019, 09:04 PM
  5. My Camera On My Phone Keeps Coming On And Snapping Pics?
    Last Post: 03-16-2019, 08:49 PM
