When we try to connect Samsung S9 plus and Samsung S8 plus for USB debugging via Vysor, It's throwing an error "Check your Android device and accept the allow USB debugging prompt. You may need to disconnect and reconnect your android for the dialog to show." We observe that this issue is occurred just because of "Automatically turn off USB debugging when not in use for 10 minutes" as mentioned on the USB debugging label.
If any one faced this type of issue or know how to enable the USB debugging check box continuously while phone is locked or in Ideal state.
Thanks in Advance.
04-05-2019 06:30 AM
