1. methodman89's Avatar
    Have not seen it discussed in a while. My S8Active updated and I have the solution figured . Able to perform a long press to launch an app, without delay or splashes.
    If known, ignore this post.
    If not, I'll post it.
    04-20-2019 10:13 AM
  2. B. Diddy's Avatar
    It doesn't hurt to post it. It'd probably be best to post it in the general S8 forum, thanks!
    04-20-2019 01:42 PM
  3. methodman89's Avatar
    I wasn't sure if anyone posted the solution.
    Search produced nothing positive.
    Download bxactions.
    Settings, Applications, select upper drop down menu, select Special Access, then select Apps That Can Change System.
    Scroll down untoggle all Bixby labeled choices.
    Toggle on bxactions if not on.
    Now, go to Home. Open and select Active in the bxactions App. Choose what you want. Activate with a long bixby button press.
    Good luck!
    B. Diddy likes this.
    04-20-2019 08:47 PM
  4. B. Diddy's Avatar
    Cool, I'm going to move this thread to the S8 forum!
    04-21-2019 12:18 PM
  1. Replies: 4
    Last Post: 04-20-2019, 02:01 PM
  2. What can the roav bolt do that my pixel 2 wont?
    Last Post: 04-20-2019, 06:38 AM
  3. Why I cant see the name of my contacts when they call me?
    Last Post: 04-20-2019, 05:53 AM
  4. Can a factory reset happen by accident when a broken phone is being fixed?
    By justaquestion in forum Samsung Galaxy S8 & S8+
    Last Post: 04-19-2019, 10:08 PM
