1. Ladybird Linda's Avatar
    I can connect bluetooth to my Skoda Yeti however I'm not able to connect my music. What am I not doing right? The track playing is showing on the screen of my Yeti however the music is coming out of my phone! So frustrating x
    04-27-2019 08:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Bluetooth when the phone is connected to the car, then tap the gear icon next to the car listing. Is Media Audio turned on?
    Also, are any other Bluetooth devices connected to the phone at the same time, like a BT headset?
    04-27-2019 10:02 AM
  3. Ladybird Linda's Avatar
    Hi ~ I've tried turning on media Audio but it just switches off. No other devices connected.
    04-28-2019 03:28 AM
  4. B. Diddy's Avatar
    What model year is the car, and is this the factory-installed stereo or an aftermarket head unit? Do you know if there are any firmware updates available for the stereo?
    04-30-2019 01:01 AM
  5. Ladybird Linda's Avatar
    It's a Skoda Yeti 4x4, 2014 model & yes it's a factory installed until. Not sure on updates however reading through many posts it seems like the problem lies with the phone not the car.
    04-30-2019 02:31 AM
  6. Ladybird Linda's Avatar
    My husband has no problems connecting
    04-30-2019 05:34 AM
  7. B. Diddy's Avatar
    Does this happen in Safe Mode as well? https://support.t-mobile.com/docs/DOC-34283. You'll only be able to test preinstalled apps, but it could help determine if some app you installed is interfering with this function.
    04-30-2019 10:46 AM
  8. Ladybird Linda's Avatar
    I'm just going to give up & listen to the radio only ~ it's far too annoying & time consuming!! Very disappointed with Samsung, it's clearly a problem with the phone as my husband's iPhone works perfectly! Maybe time for change x
    05-01-2019 04:45 PM
  1. "paste and clipboard" in messages app
    By 11B1P in forum Samsung Galaxy S10 & S10+
    Last Post: 05-01-2019, 10:40 AM
  2. Replies: 7
    Last Post: 04-28-2019, 04:20 PM
  3. Root s9 SM-G960U1 not working
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 04-27-2019, 01:18 PM
  4. Root s9 SM-G960U1 not working
    Last Post: 04-27-2019, 07:29 AM
