1. Dave McQueen's Avatar
    Hi
    Since Friday my USB-C charging port has stopped working.
    Some of the time it will charge when off and some of the time it won't.
    Even a couple of times it has when on, but when i unplug it and put the charger back in nothing.
    I have cleaned it with
    Toothpick(Plastic).
    Toothbrush
    Denture stick with the bristles that goes between the gaps in your teeth.
    Compressed air
    And as a last resort contact cleaning fluid
    And still the same.
    I've also done a factory reset in case it was an app that was the issue.
    I thought it might be the pins, but they look ok as in as much as i can see them.
    Any idea if anything else i can do?
    Thanks
    08-04-2019 06:52 PM
  2. PapaGary's Avatar
    Try another cord.
    08-04-2019 07:40 PM
  1. Notification not playing sound
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 08-06-2019, 04:59 PM
  2. My phone won't charge my battery past 5%
    Last Post: 08-05-2019, 09:58 PM
  3. Message app does not work properly. Galaxy J7.
    Last Post: 08-04-2019, 05:07 PM
  4. Swipe through photos has stopped working, any ideas how to turn it back on?
    Last Post: 08-04-2019, 02:06 PM
  5. Notification not playing sound
    Last Post: 08-04-2019, 11:50 AM
