My S8 is only about 18 months old but the battery life has plummeted and is getting worse by the day so I'll have to get it replaced. Doesn't appear to be a software issue.
Apparently the battery retains 80% of its capacity and that might be true, but despite there being nothing incriminating in the usage, it simply discharges at a much faster rate than it once did.
I can either have Samsung do it, or I can take it to the local place in town who come recommended.
I have the phone's OS locked on Android 7 by means of a package blocker and, battery life aside, it's perfect as it is. So I'd really rather not reset the thing to wipe all the data before submitting it.
There's nothing "embarrassing" on it that if seen would make me want to disappear into a hole in the ground, but on the other hand, I don't want anyone poking around at what's on it nor fiddling with any of the settings, nor changing any software or the OS. I'd like it back exactly as is just with a new battery.
I'm assuming that the battery replacement does not require the repairer to do anything more than simply turn it on afterwards and make sure it boots up normally.
While I don't imagine the security on these things is exactly hard to bypass for someone minded to do so, what's the risk in submitting it as it is, without the PIN number to access it?
And given that Samsung's batteries appear to be poor, as evidenced by the short life of this one, is there an after-market recommendation I could get the shop in town to fit?
