10-14-2019 10:25 AM
61 123
tools
    When you have the option(which i like to use for obvious security reasons) on the S8+ at least you have to hit the power button 3 times to look at the notification screen(home button just simply cant go there) i would like to know why this happens now, i font know why, it happened seemingly with no reason, there was no update on my phone, my phone is up to date, it just simply started doing this, please help me fix it
    10-11-2019 12:38 AM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist
    https://forums.androidcentral.com/sh...d.php?t=409154
    10-11-2019 08:16 AM
  3. mustang7757's Avatar
    If you go to settings then lockscreeen can change amount of time before the device locks
    10-11-2019 08:18 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Sorry, can you clarify what your question is? Are you saying that when you turn off the screen by pressing the Power button, and then wake the screen (but don't unlock it), you don't see the lockscreen notifications?
    10-11-2019 10:34 AM
  5. Dom Ger's Avatar
    Change it to what?
    10-11-2019 10:58 AM
  6. mustang7757's Avatar
    Change it to what?
    Hi, welcome!
    I'm saying if you don't set it to immediately lock the home screen can set longer if you choose (default is lock in 5 seconds ) also if you turn AOD off you should get to the lock screen quicker
    10-11-2019 11:02 AM
  7. Dom Ger's Avatar
    When i try to turn on the screen but not unlock it the phone automatically goes to the pin screen, doesnt matter if i hit home or power, i want to turn the screen on to look at my notifications, i cant always fiddle with my phone if it isnt something serious, if i turn the setting off then it doesnt do it any more, neither home nor power, i just want it to work like it used to
    10-11-2019 11:03 AM
  8. Dom Ger's Avatar
    Hi, welcome!
    my issue is im not trying to unlock my phone, i just want to see my notifications without unlocking my phone but it want to unlock any time the screen turns on when that setting is on
    10-11-2019 11:06 AM
  9. mustang7757's Avatar
    You have double tap to wake feature that can do this , do you use AOD ?
    10-11-2019 11:08 AM
  10. Dom Ger's Avatar
    what do you mean by double tap to wake feature? and i do but ive always had that on and it wasnt a problem before, just like it wasnt a problem to lock the screen with the power button before
    10-11-2019 11:11 AM
  11. mustang7757's Avatar
    Screenshot:Why does the "Lock instantly with power key" skip the notification screen?-screenshot_20191011-121828_settings.jpeg
    10-11-2019 11:18 AM
  12. mustang7757's Avatar
    10-11-2019 11:20 AM
  13. Dom Ger's Avatar
    Screenshot:Click image for larger version.
    okay, while thats cool and all once again i dont think i should have to use that, unless samsung decided to say "the older phones dont get a choice and must mess up this setting" theres no reason why this doesnt work, im just annoyed, honestly im not going to easily change my instinct of "pull phone out turn on" to pull phone out and double tap, im going to try it but that doesnt really fix the problem, never mind, apparently S8+ doesnt have it, at least not in the same place
    10-11-2019 11:23 AM
  14. mustang7757's Avatar
    You can type in the search bar of settings and find it easier instead of going through menus, if your on andriod 9 (pie) its has some changes then android 8 (oreo) I cant check my s8+ because battery went on it , but my s9+,note9,s10+ and Note 10+ is like this
    10-11-2019 11:27 AM
  15. Dom Ger's Avatar
    i just searched double tap, the option isnt there
    10-11-2019 11:30 AM
  16. mustang7757's Avatar
    Are you on android 9?
    10-11-2019 11:32 AM
  17. Dom Ger's Avatar
    the about phone section says android version 7
    10-11-2019 11:33 AM
  18. mustang7757's Avatar
    Settings scroll to about phone
    Your on Android 7?
    10-11-2019 11:37 AM
  19. Dom Ger's Avatar
    Your on Android 7?
    thats what it says
    10-11-2019 11:41 AM
  20. mustang7757's Avatar
    thats what it says
    You should be on Android 9
    Check for update
    10-11-2019 11:52 AM
  21. Dom Ger's Avatar
    i checked yesterday but ill check again, "your samsuns is up todate, No update is necessary at this time"
    10-11-2019 11:53 AM
  22. Dom Ger's Avatar
    Check for update
    no updates
    10-11-2019 11:59 AM
  23. mustang7757's Avatar
    no updates
    Maybe try using smart switch on the computer
    10-11-2019 12:18 PM
  24. B. Diddy's Avatar
    Nougat is pretty out of date -- 2 full versions behind what an S8 should be on, and 3 full versions behind the most current (Android 10). I agree with mustang7757, definitely use Smart Switch to see if you can update that way. Your issues might be solved by having a more current Android version.
    If Smart Switch doesn't give you the option to update, then did the phone originate from a different carrier than the one you're using now? Carrier-specific phones typically need to be on that original network to get the official system update over-the-air. Or did someone flash a different firmware on the phone to make it compatible with your region?
    mustang7757 likes this.
    10-11-2019 12:32 PM
  25. Dom Ger's Avatar
    im on a different carrier but even if i need to update that wouldnt explain why there would be any reason a feature would one day stop working properly and just annoy someone with taking away a quality of life feature
    10-11-2019 12:41 PM
61 123
  1. Longtime Note user bored with 10+. Thinking of making the switch to iPhone
    By onlybuilt1906 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 11-19-2019, 01:35 AM
  2. Why are incoming texts on my Galaxy 4 not differentiating who is sending them?
    Last Post: 10-11-2019, 11:50 PM
  3. I keep getting emails from hostedfiles i.dont know why or how to stop them
    Last Post: 10-11-2019, 01:59 PM
  4. Replies: 3
    Last Post: 10-11-2019, 11:47 AM
  5. Why don't I have a video call Icon on Kik anymore?
    Last Post: 10-10-2019, 04:28 PM
