1. mthom5's Avatar
    Anyone have any luck charging with a popsocket? If so what charger are you using? It won't work with my old Samsung charger I got when I bought my s7 a couple years ago.
    jlhiowa likes this.
    03-25-2018 02:48 PM
  2. Rukbat's Avatar
    Two of the materials you can get a PopSocket in are aluminum and metallic diamond - and that would prevent wireless charging. With any wireless charger. Wood may or may not be too thick to allow wireless charging. (They should have thought of that and made a thin plastic one.)
    jlhiowa likes this.
    03-25-2018 04:39 PM
  3. rimz808's Avatar
    no luck for me as of yet and I have the new Samsung wireless convertible charging pad. the pop socket goes directly over the ideal spot on the phone which is where the charger needs to be. I love my pop socket so thinking of either forgoing the wireless charger or just taking the socket off at night when I want to charge it
    jlhiowa likes this.
    03-25-2018 07:11 PM
  4. matther22xdroid's Avatar
    My wife has a pop socket on her iPhone, she enjoys it as she takes alot of selfies. I don't have use for one but I believe it's one of those things that if you get one you're sacrificing other stuff to have it.
    03-26-2018 06:25 PM
  1. Galaxy s9+ - Talkback crashing and deactivates volume key
    Last Post: 03-28-2018, 11:08 AM
  2. Why is my wifi going on and off like every 5 to 10 seconds
    Last Post: 03-25-2018, 07:17 PM
  3. Simultaneous camera and YouTube app failure on Pixel XL
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 03-25-2018, 02:27 PM
  4. Deleted photos and videos reappear on my Samsung Galaxy S5.
    Last Post: 03-25-2018, 02:20 PM
  5. Why cant i change my date and time in setting on my phone
    Last Post: 03-25-2018, 11:50 AM
