1. virginiaebdpappas's Avatar
    Hi, I am looking for a portable battery for the "galaxy S9 plus" but I would like to buy one that provides fast charging to the phone according to its characteristics (also good brand-warranty, fast portable battery charger).
    i found that the samsung galaxy s9 plus has:
    USB 3.1 - C1.0
    5.0V/2.0A
    Fast battery charging (Quick Charge 2.0) 18W
    I found these four names of batteries in Amazon that seem the best ones but I cannot decide which one would provide faster charging - does my phone support qualcomm quick charge - power IQ 2.0 18W?
    Thank you so much!!!
    Virginia
    Anker PowerCore II, 20000 mAh, powerbank, external battery with PowerIQ 2.0 and two USB-A ports, iPhone 8, 8 Plus, 7, 6s, 6 Plus, and Samsung Galaxy and other devices, black
    Anker PowerCore 20100 - Ultra High Capacity Power Bank with one of the Most Powerful 4.8A Output, PowerIQ Technology for iPhone 7 /6s /SE, iPad and Samsung Galaxy S8 / S7 and More (Black)
    USB C Battery pack RAVPower 20100mAh Power Bank Qualcomm Quick Charge 3.0 Input and Output Type C Portable Charger for for Nintendo Switch, iPhone XS/XS MAX/XR, Galaxy S8/S9, 12-inch MacBook, and More
    Power Bank RAVPower 20000mAh Battery Pack Portable Charger with Dual iSmart 2.0 USB Ports, 2.4A Input for iPhone XS/XS MAX/XR, Galaxy S9/S8 and More Mobile Phones - Black
    11-18-2018 09:40 AM
  2. belodion's Avatar
    ‘Best’ and ‘fastest’ do not necessarily mean the same thing, nor is it likely that members will have tried them all and thereby be in a position to pass judgment, but I’ll nevertheless move the thread to the S9 Accessories forum.
    11-18-2018 01:38 PM
  3. nsanders's Avatar
    I bought a Jackery battery for my S6, and l love it.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    01-10-2019 10:33 AM
  4. Tran Trung Le's Avatar
    USB 3.1 - C1.0
    5.0V/2.0A
    Virginia
    I have been using up to 10 different batteries last year and even made some myself.
    I would recommend anker powercore ii to you, due to its good charging speed, good design, good capacity. The micro usb input will not bother you too much, since 20,000mah is more than enough to get you through 2 days of heavy use.
    01-20-2019 09:45 AM
  1. which firmware does i choose for sm-g935t?
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 11-24-2018, 08:54 AM
  2. Recent Samsung Security Patch installed unwanted apps
    Last Post: 11-23-2018, 10:29 PM
  3. Replies: 1
    Last Post: 11-18-2018, 11:21 AM
  4. Samsung J730F touch not working after Oreo update
    Last Post: 11-18-2018, 08:08 AM
  5. Replies: 0
    Last Post: 11-18-2018, 07:44 AM
