Purchased a Samsung USB-C cable with travel adapter from a Samsung store. A couple of days after buying it, I found multiple bumps on the cable. What is this? Will this bump break my charger?
You stated in one of your two other posts, which are Mod-deleted, that this is for an S9+, so I've moved it to the relevant forum.Purchased a Samsung USB-C cable with travel adapter from a Samsung store. A couple of days after buying it, I found multiple bumps on the cable. What is this? Will this bump break my charger?
Ok. Thank you.You stated in one of your two other posts, which are Mod-deleted, that this is for an S9+, so I've moved it to the relevant forum.
Can you post photos of the bump? That would help us figure out what may be going on.
In general, if the bumps are new and weren't there when you purchased them, that's not a good thing. If it's on the charger, that could easily be something shorting out and overheating, melting the plastic. If it's the cable (the post title said the charger had bumps, but your actual post says it's the cable, so I'm including both), that could be something kinked, which can lead to broken wires and potential short that can cause damage to the phone and/or other items nearby.
Without seeing an example of the problem, I'm just pointing out a worse case scenario. If the bumps look to be part of the design, then it could also be nothing to worry about.
Definitely a sign of bad cable, especially with the black spots (possible signs of shorting between wires). If it's still within the exchange/warranty period, I'd try to take it back to the store. If they won't exchange it, most any USB-C cable should work, as long as the end for the charger matches (either USB-A or -C).
Whatever you do, do not use that cable anymore. It looks to pose a fire hazard, plus potential phone damage. The charger itself is likely ok if you have another cable to use.
The good news is that cables are fairly cheap. I always keep a spare or two around because they inevitably do go bad.Actually, those are just shadows. But if the bumps are a sign of a bad cable I guess I should try to find another one somewhere else because I have already left the area of the store I had bought it from. Thanks for the help.
