05-06-2020 12:27 AM
29 12
tools
  1. mustang7757's Avatar
    Yeah, when you look at frequency it stated that WiFi calling gave me an average of 8 notifications per day. That seems about right.
    Yeah thats unusual for wifi calling to do that , let's see
    05-05-2020 09:33 PM
  2. B. Diddy's Avatar
    Can you try turning Wi-fi Calling off to see if the errors go away?
    Also, are you using a VPN on your wi-fi network? If so, try turning that off.
    05-05-2020 09:35 PM
  3. mustang7757's Avatar
    No need to turn wificalling off but giving 8 notification a day that shouldn't can disable its notifications
    05-05-2020 09:48 PM
  4. B. Diddy's Avatar
    I figured it's another way to identify the culprit, in case the OP might still want other notifications related to wi-fi (not sure what other notifications that particular service might give).
    05-06-2020 12:27 AM
29 12
  1. Forgot xhide pin and location
    Last Post: 04-30-2020, 12:02 PM
