05-22-2020 02:05 PM
54 123
tools
  1. demonicvampiregirl's Avatar
    I have a refurbished Samsung Galaxy S9+ from a different website that isn't the carrier (backmarket) it was said it was unlocked to work with T-Mobile, Sprint, AT&T and Verizon. Well, Verizon is the service I want to use and the sim card I have installed. Apparently on StraightTalks website, my phone is active. However, booting my phone it still says T-Mobile and I cannot call, text or even use data on my phone. I have tried everything suggested from taking the sim card out, rebooting my phone every 20 or so minutes for an hour, to changing some settings in the phone.
    Anyone got suggestions on how to help? It's supposed to be switching to Verizon but wont, it still constantly says T-Mobile. I don't want to send it back and I currently do not have a working phone as my Samsung Galaxy S6 is now deactivated due to them switching the service.
    05-21-2020 06:33 AM
  2. lucianus_luciferus's Avatar
    If it shows the t-mobile logo when you power the phone on then I think it means the phone was (and maybe still is) locked on t-mobile.
    Go to settings, about phone, status, sim card status.
    What does it show there?
    Aggie33569 likes this.
    05-21-2020 07:16 AM
  3. demonicvampiregirl's Avatar
    It says network not available, mobile network state is unknown, service state is out of service, IMS registration status is not registered, signal strength is -113 bDm 0 asu, mobile voice network type unknown, mobile data network type unknown, and roaming is not roaming.
    We even contacted t-mobile and they said it wasn't locked. So I have no idea what to do from there. I even tried a trick I saw on a YT video, but I think my connection in my house isn't helping for that. May have to go somewhere else and try it.
    05-21-2020 07:54 AM
  4. lucianus_luciferus's Avatar
    Have you tried a factory reset? That would be the first thing to do when buying a second hand phone.
    05-21-2020 08:00 AM
  5. demonicvampiregirl's Avatar
    No I have not. Would I need to take my sim card out before I do this or would it be best if it was left in? I don't got much time to do it right now so will do so in a few hours, will message when I do.
    05-21-2020 08:26 AM
  6. mustang7757's Avatar
    Go to settings >about phone >software information> post a screen shot of that page .
    Then go to settings >connection >mobile network >access point > screen shot of that and network tap with screen shot.
    05-21-2020 08:27 AM
  7. demonicvampiregirl's Avatar
    I hope these are correct. Was not sure which one you wanted for the network tab.
    Attached Thumbnails Samsung Galaxy S9+ unlocked won't connect?-screenshot_20200521-095558_settings.jpg   Samsung Galaxy S9+ unlocked won't connect?-screenshot_20200521-100034_call-settings.jpg   Samsung Galaxy S9+ unlocked won't connect?-screenshot_20200521-100043_settings.jpg
    05-21-2020 09:02 AM
  8. lucianus_luciferus's Avatar
    You can leave the sim card in.
    05-21-2020 09:10 AM
  9. demonicvampiregirl's Avatar
    Alright, thank you!
    Let me know if you need anything else and if the network one is the correct tab you wanted. Will do the factory reset after you reply so I'm not messing anything up.
    05-21-2020 09:14 AM
  10. mustang7757's Avatar
    Alright, thank you!
    Ok thank you looking over it
    05-21-2020 09:36 AM
  11. mustang7757's Avatar
    Alright, thank you!
    Ok this phone is orginally sprint, looks like you had tmobile sim with tap talk , now you want use Verizon ? Do you have the Verizon sim in it ? There is No APN
    05-21-2020 09:41 AM
  12. demonicvampiregirl's Avatar
    Yes, I want to use Verizon and the sim card is in the phone currently. Using StraightTalk for the provider.
    05-21-2020 09:45 AM
  13. mustang7757's Avatar
    Ok , just to verify you have the Verizon sim from taptalk in the phone?
    05-21-2020 10:13 AM
  14. methodman89's Avatar
    Does this phone have the correct bands? Was CDMA on Verizon, now GSM on tmobile?
    05-21-2020 10:54 AM
  15. mustang7757's Avatar
    They do , it supports all 4 carriers
    Problem is those tap talk sim , and didn't populate a APN
    methodman89 likes this.
    05-21-2020 11:05 AM
  16. demonicvampiregirl's Avatar
    No, I have a StraightTalk Verizon sim card in, not a taptalk.
    05-21-2020 05:43 PM
  17. mustang7757's Avatar
    Thats what I meant lol
    05-21-2020 05:55 PM
  18. demonicvampiregirl's Avatar
    Oh, sorry I thought tap talk was it's own service. Dx But yes, it's straight talk, verizon and sim card is within my phone.
    05-21-2020 06:10 PM
  19. mustang7757's Avatar
    No my fault mixed the names up lol
    Umm..try resetting the APN see if it populates one , like in your screen shot, straight talk is little funny with these phones
    05-21-2020 06:31 PM
  20. demonicvampiregirl's Avatar
    Okay, so I just noticed there was an app for T-mobile that would unlock my phone, going into it, it says it's locked. Would a factory reset fix that with the new sim card in?
    05-21-2020 07:07 PM
  21. mustang7757's Avatar
    No
    BergerKing likes this.
    05-21-2020 07:08 PM
  22. mustang7757's Avatar
    It probably added it with tmobile sim , this is a sprint phone
    05-21-2020 07:09 PM
  23. demonicvampiregirl's Avatar
    No
    That sucks, hopefully I can get the unlock app to work then after updating some stuff. Kept saying some server error.
    05-21-2020 07:10 PM
  24. demonicvampiregirl's Avatar
    Which is why I was asking if setting it back to a sprint phone and redoing this with the sim card would remove the t-mobile crap.
    05-21-2020 07:10 PM
  25. mustang7757's Avatar
    Server error because its not a tmobile device
    Can uninstall it
    05-21-2020 07:10 PM
54 123
  1. Smart View: (mirror/cast) Galaxy A70 to Windows 10 PC?
    Last Post: 06-05-2020, 01:43 AM
  2. Replies: 2
    Last Post: 06-03-2020, 05:38 PM
  3. I am experiencing Boot Issue, Samsung Galaxy A30s.
    Last Post: 06-03-2020, 05:33 PM
  4. ZOOM upgrade not compatible with Galaxy Tab 3...
    Last Post: 06-03-2020, 04:31 PM
  5. Bluetooth message saying auto connect when not in use.
    Last Post: 06-03-2020, 12:48 PM
