1. gkitf16's Avatar
    I have the S9 on Android 10 build QP1A.190711.020G960U1UES7DTD1. The rear camera video recording looks horrible, set at UHD 60 FPS. I took this clip yesterday in bright daylight. I have a Sandisk Extreme Pro 64GB card in the tray which has checked out at 88mbps write speed, so that wasn't hurting anything. The shot was ruined, pixelated junk. The file properties on my computer show 320 x 240 15 fps resolution????? WTF??!?
    Youtube didn't downsample it, not much worse it could get! Quality settings there confirmed it was 240p resolution! That's not even in the camera menu, the lowest you can get is HD 1280 x 720!
    https://mega.nz/file/pcBWRCrA
    The file size is 853 kb for a 48 sec. clip. I reset the camera settings and seems to be fixed. WHAT would ever make it go to that low a setting? Even that looks halfway acceptable after resetting the app.
    05-23-2020 04:52 PM
  2. lucianus_luciferus's Avatar
    Must have been a software glitch
    05-23-2020 05:20 PM
  3. B. Diddy's Avatar
    Where did you get the card? Counterfeit cards are unfortunately somewhat common, so if you didn't get it from a well-known well-established retailer, there's more chance it's not legit (and might therefore lead to results like this).
    05-23-2020 09:38 PM
  1. Samsung S20 Ultra and WhatsApp video problems?
    By Kawar in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 08-05-2020, 11:19 AM
  2. Buying a new phone, any input on an inexpensive device with a great camera?
    Last Post: 06-02-2020, 06:46 PM
  3. Camera problem
    By methodman89 in forum Ask a Question
    Last Post: 06-02-2020, 10:31 AM
  4. camera slow motion
    By mito88 in forum Samsung Galaxy Tab S6
    Last Post: 06-02-2020, 08:58 AM
  5. Why can't I locate my private videos and picture
    Last Post: 06-01-2020, 05:37 PM
