1. iainr's Avatar
    I recently had the screen replaced on my S9. Since the replacement, it won't connect to the phone network (O2, UK). It shows that it is picking up a signal, but will not register on the network at all. When I try to register it, the signal strength display immediately drops to zero and I get the message "unable to connect". The SIM card that I am using works fine in an old S7.
    I have tried:
    Dropping to 2G/3G only mode.
    Deleting and recreating the APN.
    Booting to safe mode.
    A soft reset.
    A factory reset.
    All to no avail.
    I took the phone back to the man that repaired it, he was able to get his SIM working in the device (after some time spent fiddling with settings), but couldn't get mine to work. He is disclaiming responsibility for the issue as a result of him being able to get it to work. I'm a bit stumped as to what to try next. Any suggestions gratefully received.
    06-08-2020 08:17 AM
  2. Kizzy Catwoman's Avatar
    I am wondering if an antenna got damaged when he fixed it. Did he tell you which network he connected to with his own sim card? Unless he tried with an O2 sim it may not be relevant to why your sim card isn't working.
    Please register for an account so we can help you further. With a guest account, you can't reply. Thanks
    https://forums.androidcentral.com/sh...d.php?t=409154
    Morty2264 likes this.
    06-08-2020 08:32 AM
  3. Morty2264's Avatar
    That's true. If he used a different SIM card than yours, it wouldn't necessarily be a reliable indicator that *any* SIM card could work. I'm sorry you are going through this, OP! Please keep us posted on what happens.
    06-08-2020 09:15 AM
  4. iainr's Avatar
    Hi Kirstein, thanks for replying! He used a 3 sim. I have tried to get my wife's EE sim to work and it has the same issues. I initially thought that he must have damaged the antenna, but am juts a bit confused as to why would the phone show that it was receiving a signal? Is there a way that I can test that the antenna is working properly?
    06-08-2020 09:58 AM
  5. BergerKing's Avatar
    @iainr, just wanted to take a moment and welcome you to the Android Central forums. Moved your thread to the S9 subforum, and fixed the original post to give you ownership and credit for the thread. Hope you get everything sorted!
    iainr likes this.
    06-08-2020 02:37 PM
  6. Morty2264's Avatar
    Do you have any updates on your situation, OP? Perhaps see if you could get someone with the same SIM card as you to insert theirs to see if they get a connection?
    06-09-2020 08:47 PM
  7. mustang7757's Avatar
    If yours and your wife sim doesn't work in the phone and your sim works in your other phone something happened when they changed the screen , did you see for yourself the repair guy sim worked or taking his word ?
    06-10-2020 01:39 AM
  8. iainr's Avatar
    Hi Morty2264, sorry for the slow reply. That seems like a reasonable suggestion. I'll see if I can find one.
    No update on situation, I've tried again with the phone, it did briefly connect to the network, then dropped again almost immediately. Doing some research online took me down the rabbit hole of system menus and internal configs, I've posted to a technical forum in the hope that someone might be able to help.
    06-11-2020 05:34 AM
  9. iainr's Avatar
    Hi Mustang7757, again, apologies for the slow reply. I didn't see that his sim worked directly, but I do see successful calls in the phone's log.
    Morty2264 and mustang7757 like this.
    06-11-2020 05:35 AM
  10. Morty2264's Avatar
    No problem! No need to apologize! Let us know if we can do anything else to help, and please keep us posted on what happens!
    06-11-2020 09:48 AM
  11. mustang7757's Avatar
    Hi, no problem!
    The only thing I suggest is getting a 2nd repair shop opinion they going charge but if it turns out the first guy that work on it was a fault should give you a refund for whole repair.
    06-11-2020 11:05 AM
  12. iainr's Avatar
    Just to keep everyone in the loop, I posted to this forum: https://forum.xda-developers.com/gal...creen-t4112369
    There is a reply from a poster with a similar issue, he believes that the antenna may have been damaged during the repair as a result of the significant amount of heating required to loosen the adhesive. I've spoken to the repair guy, he has agreed to fit a new antenna module. I'll update if this solves the problem.
    06-12-2020 06:44 AM
  13. Morty2264's Avatar
    That's so awesome! Good for you for going back and talking to the repair man! Yes, please keep us updated!
    06-12-2020 09:54 AM
  1. Why my is my Galaxy tablet indicating "TouchWiz has stopped working?"
    Last Post: 06-10-2020, 02:03 AM
  2. How to block any third-party apks from being downloaded on my phone?
    Last Post: 06-10-2020, 01:08 AM
  3. My Lock Screen shortcuts keep disappearing!
    By Dooki in forum Samsung Galaxy S10e
    Last Post: 06-10-2020, 12:48 AM
  4. I need help making the Gmail app the default on my phone, please help.
    Last Post: 06-09-2020, 01:36 AM
  5. Why do I never have storage space?
    By LimeS in forum Samsung Galaxy A3
    Last Post: 06-08-2020, 09:50 PM
