1. Haselsmasher's Avatar
    The broken Android Auto on Android 10 issue has pushed me over the edge. Last night I downgraded to Android 9.
    I flashed the T-Mobile firmware (I'm in the US.) While I'm on T-Mobile now, the phone is unlocked.
    Although I disabled Auto Updates, T-Mobile saw the device as needing an update before I could get the disabling of Auto Update completed. It appears T-Mobile won't let you decline an update. So as of now my system will update to Android 10 automatically tomorrow.
    Does anyone know if/how I can stop this? Or alternatively, do other vendors' firmwares force an update to be accepted? (Part of this question also address a more detailed question: At sammobile.com there are two Android US firmwares listed as "Unknown (XAS)" and "Unknown (BST)". Can someone explain these?) I haven't spent too much time customizing the phone since downgrading. So flashing different firmware now would be easy.
    Thanks!
    Jim
    06-21-2020 10:03 AM
  2. mustang7757's Avatar
    Hi
    Get Package Disabler Pro to disable any software update . https://www.packagedisabler.com/
    Laura Knotek likes this.
    06-21-2020 10:11 AM
  3. Haselsmasher's Avatar
    Thanks! It seems to have worked great! The notification the update would be automatically installed has gone away.
    Great app!
    Jim
    mustang7757 likes this.
    06-21-2020 11:12 PM
  4. mustang7757's Avatar
    Great app!
    Jim
    Your welcome!
    Thats a great app every Samsung owner should have along with Samsung Good Lock
    06-22-2020 12:14 AM
  1. My solution to the lost connection issue with my Galaxy Buds.
    By K_Daddy in forum General Help and How To
    Last Post: 08-20-2020, 11:43 AM
  2. Using Google assistant to set a timer leaves dinner clicking sound playing in background.
    By Android Central Question in forum Huawei P30 & P30 Pro
    Last Post: 06-21-2020, 05:17 PM
  3. Can I transfer SD memory card from ZTE phone to Samsung Galaxy Tab A?
    By Alexander Reznik in forum Ask a Question
    Last Post: 06-21-2020, 04:53 PM
  4. Knox/SIM card transfer to a new phone.
    Last Post: 06-21-2020, 10:15 AM
  5. Bluetooth pairs with, but will not connect to PC?
    Last Post: 06-21-2020, 07:53 AM
