1. Haselsmasher's Avatar
    [I figure this is a long-shot question. But I'll ask in case experts here have any insight.]
    Yesterday I dropped my S9 from roughly chest height onto a concrete floor. It's in a QuadLock case. It landed flat (not on a corner or side) screen side down. It was loud enough, when I picked it up, I wouldn't have been surprised if the glass broke. But it didn't.
    The phone worked normally for a couple of hours. Then while sitting on a table it spontaneously attempted a reboot and stayed on the T-Mobile splash screen continuously.
    After a bunch of futzing I got into the Android recovery screen and did Wipe Data / Factory reset. I get through phone setup. But as soon as it appears the phone is booted, when I go to use it......it reboots. I then flashed Android 10 using Odin and behavior is the same. The phone gets warm/almost-hot while going through these reboot sequences.
    Between the reset and Android 10 flash I did myself I'm kind of figuring what I'm dealing with is not a sw or configuration problem, but rather a hardware issue.
    Based on this story - any educated cases if this seems like a hardware problem?
    Thanks!
    Jim
    07-31-2020 10:46 AM
  2. mustang7757's Avatar
    Sounds like maybe something internal got shocked from the fall , did it have a case?
    07-31-2020 11:05 AM
  3. Haselsmasher's Avatar
    Yes - it was in a QuadLock case. (Which seems like a pretty good case......quite sturdy.)
    07-31-2020 11:16 AM
  4. mustang7757's Avatar
    Maybe leave the phone off for few hours then see what happens?
    07-31-2020 11:22 AM
  5. monsieurms's Avatar
    There have been occasions where updates have caused spontaneous reboots. But usually resets fix that. You dropped it. Now you have a problem. You reset. It didn't help. Hardware would seem to be the most likely answer. Hate to say it, but....
    08-02-2020 07:30 AM
  6. Haselsmasher's Avatar
    For posterity I'll follow up with the results.......
    It was a hardware problem - or at least most likely. I took it to UBreakIFix and they flashed it. Same result (constant reboot). Actually, overall behavior was getting worse with time. At first there was just enough time between reboots where you could do a Power Off. But the reboots started happening so frequently the only way to get it to stop was to have the battery run out - while continuously rebooting all the time.
    I bought a OnePlus 8. First non-Samsung phone I've owned in many years. I have to say......OnePlus makes a REALLY nice phone!
    mustang7757 likes this.
    08-02-2020 11:10 PM
  7. mustang7757's Avatar
    Thanks for update
    Congrats on the new , and they make very good phones one plus. I have 1+7pro and it's great !
    08-02-2020 11:18 PM
  1. Replies: 15
    Last Post: 07-11-2021, 02:10 AM
  2. Chrome and Android System Web View Update Issue
    By 1eyejack in forum Samsung Galaxy S10 & S10+
    Last Post: 07-31-2020, 05:03 PM
  3. Smart Lock issues.
    By urbantea in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 07-29-2020, 04:36 PM
  4. Notification issues on home Wi-Fi, but fast on mobile network?
    By Casualballer in forum Ask a Question
    Last Post: 07-28-2020, 02:11 PM
  5. whatsapp notification issue
    Last Post: 07-28-2020, 11:03 AM
