1. warlord526's Avatar
    I just did a S9 update on my phone yesterday and now I no longer get LED notifications working anymore. I was using "Light Manager" and figure since they migrated to "Light Manager 2" that I figured the original one is no longer compatible. The issue now is I can't even get the LED light to even flash without that app when I get a text or notification anymore.
    Is there a way to fix that?
    I don't want to use the "Light Manager 2" app as it seems there are a ton of issues with it, but even a generic flash for the LED would be good, but since the update on 8/12/2020, I can't get that LED to do anything other than show red when it's charging or green when it's 100% and that's all...
    08-13-2020 08:39 AM
  2. VidJunky's Avatar
    Why would you assume that an installed app would no longer work? Typically after an update, depending on the update, your device will alert you to app compatibility issues. If your device didn't prompt you to switch and the app itself didn't prompt you there was probably no reason to change.
    Since you have a Samsung you might check the Galaxy Store for Edge Lighting or similar apps which give you more control and options with lighting and notifications.
    08-14-2020 01:46 AM
  3. Mojave's Avatar
    I have the S9+ and I use LED Blinker Pro. Here is the link. https://play.google.com/store/apps/d...ledblinker.pro
    Works great on my phone with no issues. There is also a lite version of this app.....here is the link. https://play.google.com/store/apps/d...com.ledblinker
    I started out with the lite version to see how it worked and then bought the pro version. The dev is very responsive to any questions or issues.
    08-14-2020 06:25 AM
  4. warlord526's Avatar
    @VidJunky: the app was taken off Google Play for the newer Light Version 2. So there hasn't been any updates for quite a long time, even with previous versions. I uninstalled it and want to do a fresh install and that's when I noticed it's no longer avaliable that's why.
    @Mojave: I tried that one out yesterday acutually "the Lite" free version you have in the 2nd link and it didn't let me actually chose a unique color for a person when they text me. I just found it to only change the color when any text comes in and that was it (and I still couldn't get it to work). Maybe the pro version is better or maybe it does allow me to assign a unique color to a contact and I just didn't find out where that option was?
    08-14-2020 11:29 AM
  5. Mojave's Avatar
    I have never set up a color for my contacts with LED Blinker. I only have set up a color for any text I receive from my Textra app and not for my contacts. Maybe to add a specific color to a contact is only available in the Pro version. The Lite version is limited in some of the things you can do. I had a small issue months ago when my phone updated to Android 10 and the dev was very responsive. So.....I would suggest you email the developer. Best of luck!
    08-15-2020 06:26 AM
  6. warlord526's Avatar
    Thanks, I actually did some more research on it and watched a few videos on the app and noticed it doesn't actually change the physical light as the old "Light Manager" did, but makes it's own digital light on the screen. And yes, even in the description it's not designed to be used inside of other apps, just the notification of when that app has responded. So contacts would be just a single color and not individual contacts. Oh well, kind of a shame Androids have the ability to change the color of the physical LED light and then don't bother to allow you to access it in anyway other than an app...
    08-15-2020 08:51 AM
  7. cdigga101's Avatar
    Check the Galaxy Store, not Google play store, for the older light manager app. It works fine on my s9. I don't assign lights per contact tho so dunno if that would still work
    VidJunky likes this.
    08-15-2020 06:33 PM
  8. warlord526's Avatar
    And yes the older Light Manager is no longer on Play Store
    08-16-2020 03:05 PM
  9. VidJunky's Avatar
    You know the Galaxy Store is different than the Play Store correct?
    I mentioned it, cdigga101 has mentioned it and you continue to refer to the Play Store. The Galaxy Store is a Samsung offering and you should be able to find it in your Samsung apps or in your app drawer.
    I'm not a huge fan of Samsung apps but they do offer tools that work with their devices. Edge Lighting or one similar may help you solve your issue.
    08-17-2020 06:55 PM
  10. warlord526's Avatar
    See shows you how often I actually download apps. I totally forgot there are the 2 stores and only think of the one. It is on there at least, but still doesn't work since the last update. At least I do have another option to look.
    Edge Lighting I didn't like and think it was one of those things when I got my phone that was suggested to turn off because of the battery drain.
    I'll explored the Galaxy Store more, thanks for pointing that out...
    08-18-2020 11:10 AM
  1. ecg and vo2 updates!
    By Hghlndr in forum Samsung Galaxy Watch Active 2
    Last Post: 08-30-2020, 08:22 PM
  2. S20+ August update
    By Balaji V in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 08-28-2020, 02:05 AM
  3. Cannot update chrome browser app
    By friendly986 in forum Ask a Question
    Last Post: 08-17-2020, 09:43 PM
  4. Why my screen lock on my Samsung galaxy note 5 not working?
    Last Post: 08-17-2020, 09:02 PM
  5. Why does my front camera on the cellphone not work?
    Last Post: 08-16-2020, 10:46 PM
