1. Ebheykal's Avatar
    Is there any antivirus for phone Samsung S10? or anything that keep my phone less heating when I use too much social media on my phone? Thanks
    08-31-2020 05:45 AM
  2. Kizzy Catwoman's Avatar
    An antivirus will not stop your phone from overheating. When you use the phone the cpu has to work and that generates heat. Proper cooling in a phone should stop it getting too hot. Are you in the USA, Canada or China? Or are you from somewhere else? The Snapdragon chip from those areas tends to run cooler than the Exynos chip in the international version. I have an Exynos based S10+ and my phone doesn't tend to run too hot, but I know a lot of people complain about it.
    Laura Knotek, B. Diddy and Mojave like this.
    08-31-2020 06:28 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I agree with Kizzy Catwoman. Antivirus or cleaner apps would probably make your phone heat up more and bog down performance more, to be honest. They're generally useless, and often cause more problems than they claim to solve.
    Mojave likes this.
    09-01-2020 11:48 AM
  1. What appsshould have usage accuses
    Last Post: 08-31-2020, 03:24 AM
