1. karimkahale's Avatar
    Hello, I hope everyone is doing great.
    I'm currently running latest stock android 10 on my G960F D/S.
    I am trying to uninstall bloat apps like Excel/OneDrive/Maps, usually I use SD Maid or FX explorer with root of course, and I navigate to system/priv-app or system/app and delete the undesired apk. However, every single time I delete Excel for example, the app would reappear after rebooting.
    What is the definitive way to get rid of this bloatware permanently?
    Thank You for reading.
    09-03-2020 09:11 AM
  2. mustang7757's Avatar
    I welcome to AC!
    Your rooted?
    karimkahale likes this.
    09-03-2020 09:13 AM
  3. karimkahale's Avatar
    Thank you mustang7757.
    Yes I am indeed rooted, using latest magisk beta.
    I have tried uninstalling system apps manually browsing system/app with FX File Explorer with root privileges, and I also tested with SD Maid.
    None worked.
    mustang7757 likes this.
    09-03-2020 09:16 AM
  4. mustang7757's Avatar
    None worked.
    Try maybe another file explorer with root permissions
    09-03-2020 09:45 AM
  5. karimkahale's Avatar
    Looks like the apps ended up getting uninstalled after multiple reboots. Very random but oh welp. Thanks for the help anyways!
    09-04-2020 03:45 AM
  1. Keyboards... Samsung or GBoard or other?
    By Talderon in forum Samsung Galaxy Note 20 & Note 20 Ultra
    Last Post: 05-27-2021, 11:04 PM
  2. NightVision Mode (System wide red "Night mode" filter)
    By Android Central Question in forum Software Development and Hacking
    Last Post: 09-03-2020, 01:50 PM
  3. How do I get Samsung a10 e to show my text messages on home screen e
    Last Post: 09-03-2020, 11:43 AM
  4. NightVision Mode (System wide red "Night mode" filter)
    Last Post: 09-03-2020, 06:41 AM
  5. How can I access a calculator in my samsung s8+
    Last Post: 09-02-2020, 10:30 PM
