1. Blackbay16's Avatar
    Pressing and holding the notification says this notification cant be turned off,
    So I went into general management/language and input/ on screen keyboard then into manage keyboards and I see google voice typing toggled on so I turn that off,then also google voice input is on so I toggle that off aswell
    But there is another thing in there that I've never seen before and dont know how it got there as I never downloaded it, it's called Samsung keyboard neural beta so I toggle that off aswell
    This worked and got rid of the annoying android system change keyboard notification.i use only the normal Samsung keyboard
    The problem is after restarting your phone the dam android system change keyboard notification comes back.so again I go into manage keyboards and that samsung keyboard neural beta is toggles back on again..
    Everytime you restart the phone that Samsung keyboard neural beta is toggles on so it makes that annoying keyboard notification keep coming up.is there a fix guys?as it's getting annoying tbh having to keep boggling off neural beta to remove the notification.and I like to restart my phone one a day
    Sorry for the long first post
    10-16-2020 07:23 AM
  2. B. Diddy's Avatar
    Duplicate, please respond in this thread: https://forums.androidcentral.com/sa...ml#post6874892. Thread closed to prevent parallel discussions.
    10-16-2020 12:08 PM
  1. How to restore all settings (home screen icons, etc) from Google Drive backup?
    By Android Central Question in forum Google Pixel 5
    Last Post: 10-16-2020, 11:40 AM
  2. Do I recommend whether to switch to Google Pixel 4a or alternatives?
    Last Post: 10-16-2020, 02:02 AM
  3. Pixel 4 back cover coming off
    Last Post: 10-15-2020, 10:28 PM
  4. Replies: 1
    Last Post: 03-27-2015, 06:09 PM
  5. just discovered the freedom of android
    By roddymclaren in forum General Help and How To
    Last Post: 04-22-2013, 04:20 PM
