1. Greg P1's Avatar
    I got a notification that an app was causing excessive power drain, and it gave me the option to shut down the app. It was associated with Google Play somehow as a sub-app or something similar. It wasn't visible on the apps list, but Google Play was. When I went to change the settings under Google Play, they were unavailable.
    Does anyone know what's going on?
    05-22-2021 10:51 AM
  2. B. Diddy's Avatar
    Was it Google Play Services?
    Keep in mind that this kind of system reporting of power drain can sometimes flag the normal activity of a system app. If it was a one-time thing or if it's very rare, then I wouldn't worry about it. If it's pretty frequent, that's when I'd be more concerned.
    05-22-2021 11:54 AM
  3. Greg P1's Avatar
    The only problem is that my wireless charger was barely keeping ahead of the power drain. So I switched to the corded charger, but it only lasted half a day. New battery too.
    However, it seems to have subsided lately, and it seems to be returning to normal.
    I wish Samsung would give us a heads up when their updates do that.
    05-22-2021 01:25 PM
  4. B. Diddy's Avatar
    In that kind of situation, I would reboot the phone and see if the problem comes back.
    05-22-2021 01:37 PM
  1. Replies: 3
    Last Post: 05-22-2021, 12:33 PM
  2. What is the battery average per hours of Samsung a32 on mobile data
    Last Post: 05-22-2021, 12:31 PM
  3. Replies: 0
    Last Post: 05-22-2021, 04:53 AM
  4. Separate backups on samsung device
    Last Post: 05-21-2021, 09:14 PM
  5. can i have a slide show on my lock screen for my LGK31?
    Last Post: 05-21-2021, 06:15 PM
