Hi,
I just replaced my rear camera in an S9+. Upon booting everything was fine except I get no tower. I'm connect to my wife's Hotspot to post this. So WiFi is fine..
]SIM status says Network - No Connection, Mobile Network State - Disconnected. Service State - Radio Off.
I've had it back apart 3 times to confirm connections. All I can add is I heard a light crack when pressing the new camera adhesive against the board. I used a magnifying glass. No cracks it looks fine. Just throwing it out there incase this is a common issue.
Any advice would be great. I'm an E/E. But can't find a thing posted about where the radio is on the board.
I'm ready to drop 75$ on a motherboard. Thought I'd get advice before going that way.
Thanks in advance
07-11-2021 10:22 PM
