A
Welcome to Android Central! I agree with VidJunky -- the first thing we need to know is the Bluetooth device you're trying to connect, so we can review the proper way to pair it.
Not crazy about those head units , but go into developer settings by Tapping build number 7 times go to Bluetooth settings there and try different configuration and see what works . You can also see how your phone with another cars Bluetooth if u have a chance but try developer settings.Sry, Kenwood KDC-BT740DAB car stereo.
So I start the pairing process, my phone sees the head unit, my phones name appears on the head unit, the head unit says press the volume button, then says pairing, Alexa pops up on my phone to ask if I want driving mode, then after about 5-10 seconds the head unit says PAIRING NG(Disabled), the pairing fails and my phone says check settings?
The manual says "For some Bluetooth devices, you may need to enter the PIN code immediately after searching". Maybe my phone should be asking for the PIN but for some reason isn't?
I have cleared Bluetooth data and cache, restarted my phone(Galaxy s9), I have removed the aftermarket case from the phone, held the phone right next to the head unit.
I have deleted cache, reset network, unchecked power saving, restarted the app, I'm out of ideas
I did what you said, went back to settings and searched "Bluetooth", wow there are a lot of BT settings. What should I try?
First and last picture try those settings, just remember or screen shot your stock values
When pairing, do you have it set to use both audio and call Bluetooth connections? I don't have experience with that specific radio, but I've had some in the past that would fail if I tried to connect only as media streaming (I use a headset for calls).
When you go into your Bluetooth settings on the phone to look at the devices you paired with, then go into the options for a specific device, you'll see a call and media setting. If you are setting up a new pairing, it should ask how you want to set this, usually defaulting to both turned on. If the call setting is turned off, it's caused me problems with initial pairing.Sorry, not sure what you mean, what setting is this?
If you get a chance try your device in another car with Bluetooth that way we know for sure if its your device or the head unitI tried every option in your screenshots, plus "turn off AVC block list", and "Bluetooth audio LDAC codec: Playback quality" to "Optimised for Connection Quality", I also deleted cache, and reset network again. No luck.
I agree , one of the more easier steps to troubleshoot and know which direction to goIt may be easier to have a friend or someone connect to your head unit see what result they get. If they are able to get and maintain a connection you then try to reproduce their settings.
