Galaxy S9 will not connect to Kenwood head unit via Bluetooth.
I have deleted cache, unchecked power saving, restarted the app, I'm out of ideas.
re: Galaxy S9 will not connect to Kenwood head unit via Bluetooth.
Welcome to Android Central.
What is the device you are attempting to connect to?
Have you read the user's manual for this device on how to connect?
Does the device appear in your list of possible connections? If so, is the device greyed out, unresponsive when tapping the link or what is it that you're experiencing?
The steps you've taken are typical steps for solving issues like this but with limited information there isn't much else that we can add without simply guessing. If you would like to reply to this thread and receive notifications when others leave replies, please create an account. This link will help you do that.. https://forums.androidcentral.com/as...-new-post.html
Try reset network, go settings >general management >reset>reset network
Can also try in safe mode if it's OK in that mode
Welcome to Android Central! I agree with VidJunky -- the first thing we need to know is the Bluetooth device you're trying to connect, so we can review the proper way to pair it.
Originally Posted by
B. Diddy Welcome to Android Central! I agree with VidJunky -- the first thing we need to know is the Bluetooth device you're trying to connect, so we can review the proper way to pair it.
Sry, Kenwood KDC-BT740DAB car stereo.
So I start the pairing process, my phone sees the head unit, my phones name appears on the head unit, the head unit says press the volume button, then says pairing, Alexa pops up on my phone to ask if I want driving mode, then after about 5-10 seconds the head unit says PAIRING NG(Disabled), the pairing fails and my phone says check settings?
The manual says "For some Bluetooth devices, you may need to enter the PIN code immediately after searching". Maybe my phone should be asking for the PIN but for some reason isn't?
I have cleared Bluetooth data and cache, restarted my phone(Galaxy s9), I have removed the aftermarket case from the phone, held the phone right next to the head unit.
I have deleted cache, reset network, unchecked power saving, restarted the app, I'm out of ideas
lifeofbrian Sry, Kenwood KDC-BT740DAB car stereo.
Not crazy about those head units , but go into developer settings by Tapping build number 7 times go to Bluetooth settings there and try different configuration and see what works . You can also see how your phone with another cars Bluetooth if u have a chance but try developer settings.
mustang7757 Not crazy about those head units , but go into developer settings by Tapping build number 7 times go to Bluetooth settings there and try different configuration and see what works . You can also see how your phone with another cars Bluetooth if u have a chance but try developer settings.
I did what you said, went back to settings and searched "Bluetooth", wow there are a lot of BT settings. What should I try?
lifeofbrian I did what you said, went back to settings and searched "Bluetooth", wow there are a lot of BT settings. What should I try?
I know , it's kinda trial by error see which sticks
3 Attachment(s)
First and last picture try those settings, just remember or screen shot your stock values
What happens if you tell Alexa you don't want Driving Mode?
Re: Galaxy S9 will not connect to Kenwood head unit via Bluetooth.
mustang7757 First and last picture try those settings, just remember or screen shot your stock values
I tried every option in your screenshots, plus "turn off AVC block list", and "Bluetooth audio LDAC codec: Playback quality" to "Optimised for Connection Quality", I also deleted cache, and reset network again. No luck.
When pairing, do you have it set to use both audio and call Bluetooth connections? I don't have experience with that specific radio, but I've had some in the past that would fail if I tried to connect only as media streaming (I use a headset for calls).
Mooncatt When pairing, do you have it set to use both audio and call Bluetooth connections? I don't have experience with that specific radio, but I've had some in the past that would fail if I tried to connect only as media streaming (I use a headset for calls).
Sorry, not sure what you mean, what setting is this?
1 Attachment(s)
lifeofbrian Sorry, not sure what you mean, what setting is this?
When you go into your Bluetooth settings on the phone to look at the devices you paired with, then go into the options for a specific device, you'll see a call and media setting. If you are setting up a new pairing, it should ask how you want to set this, usually defaulting to both turned on. If the call setting is turned off, it's caused me problems with initial pairing.Attachment 337120
lifeofbrian I tried every option in your screenshots, plus "turn off AVC block list", and "Bluetooth audio LDAC codec: Playback quality" to "Optimised for Connection Quality", I also deleted cache, and reset network again. No luck.
If you get a chance try your device in another car with Bluetooth that way we know for sure if its your device or the head unit
mustang7757 If you get a chance try your device in another car with Bluetooth that way we know for sure if its your device or the head unit
It may be easier to have a friend or someone connect to your head unit see what result they get. If they are able to get and maintain a connection you then try to reproduce their settings.
VidJunky It may be easier to have a friend or someone connect to your head unit see what result they get. If they are able to get and maintain a connection you then try to reproduce their settings.
I agree , one of the more easier steps to troubleshoot and know which direction to go
mustang7757 I agree , one of the more easier steps to troubleshoot and know which direction to go
Had my nephew try and pair his Galaxy S8, did it first time. So how do I get my Bluetooth working? Hopefully not a factor reset.
lifeofbrian Had my nephew try and pair his Galaxy S8, did it first time. So how do I get my Bluetooth working? Hopefully not a factor reset.
Hopefully you dont have to factory reset .
Go to settings>general management>reset>reset network ...this will reset all wifi, network,Bluetooth
mustang7757 Hopefully you dont have to factory reset .
Done that a few times, never worked.
lifeofbrian Done that a few times, never worked.
We running out of options unfortunately, which means factory reset :(
mustang7757 We running out of options unfortunately, which means factory reset :(
To be honest, I don't think that will help.
We've been looking at this from the phone side of things so far. I don't recall if you tried anything with the radio. Have you?
-Does your radio still show your phone in its list? If so, what happens if you try to initiate the connection from the radio?
-Try deleting all pairing info from the radio (check your manual for that), then go through the pairing process again.
-Try fully resetting the radio
I'm wondering if the glitch lies with the radio and not the phone.
Mooncatt To be honest, I don't think that will help.
If they tested with another phone then something going on with OP, no?
