12-23-2021 01:09 PM
32 12
tools
  1. mustang7757's Avatar
    SOLVED!!!
    First I want to thank all of you who were so generous with their time in trying to help me solve this puzzle.
    The solution was in Settings > Display > Screen Saver!
    There are a number of "savers," but I had chosen "News & Weather." Bad choice!
    The news & weather hadn't updated since 2017! And the clock would show the correct time initially but wouldn't change at all.
    Now I have selected something else and all is well!!!
    Thanks again,
    Stew
    Hmm glad you solved it but don't see news and weather under those settings in screen saverWhy does my lock screen clock not change, and news and weather stay the same?-screenshot_20211222-233503_settings.jpg
    12-22-2021 10:36 PM
  2. B. Diddy's Avatar
    Maybe the old Google News & Weather app is still on the phone? That app was discontinued by Google back in 2018, which might explain why things are stuck in 2017 in the OP's screenshot. https://en.wikipedia.org/wiki/Google_News_%26_Weather
    12-22-2021 10:39 PM
  3. mustang7757's Avatar
    Hmm not sure it would pop up on the lock screen , see my screenshot under lock screen widget it would be default Samsung weather but probably need baby routine added Why does my lock screen clock not change, and news and weather stay the same?-screenshot_20211222-235115_alwaysondisplay.jpg
    12-22-2021 10:53 PM
  4. B. Diddy's Avatar
    Hmm not sure it would pop up on the lock screen , see my screenshot under lock screen widget it would be default Samsung weather but probably need baby routine added Click image for larger version.
    But maybe it's different on an older phone like an S9?
    12-22-2021 11:14 PM
  5. mustang7757's Avatar
    I don't recall it being much different in those 2 settings mentioned lockscreen or screen saver
    12-22-2021 11:15 PM
  6. soberman999's Avatar
    Yes, I think Samsung forgot to remove it and forgot that it needs some updating! Here's a picture of my Screen Saver screen.
    Samsung Galaxy S9+ Android version 10 One UI version 2.5 << Perhaps I need to upgrade One UI to v. 3 or v 4? I thought this upgrade would be automatic, but apparently not.
    Attached Thumbnails Why does my lock screen clock not change, and news and weather stay the same?-display-screen-saver.jpg
    mustang7757 and B. Diddy like this.
    12-23-2021 01:06 PM
  7. mustang7757's Avatar
    So it was a option on older Andriod version, thanks for clearing that up .
    12-23-2021 01:09 PM
32 12
  1. Why can't GPS and Power Saving mode get along?
    By ultrarunner2020 in forum Ask a Question
    Last Post: 12-19-2021, 07:11 AM
  2. How long will it take for my answer
    Last Post: 12-13-2021, 01:52 AM
  3. Why is my phone dm-verity corrupted ?
    Last Post: 12-09-2021, 01:46 AM
  4. Replies: 2
    Last Post: 12-08-2021, 09:08 PM
  5. Replies: 0
    Last Post: 12-08-2021, 03:35 PM
