    Hello,
    I noticed when I record video on my Samsung Galaxy s9+ (using the front camera), the audio quality will sound normal, but at some point, the audio quality will drop, as if someone lowered the bass or treble. It will last a few seconds before eventually returning to normal.
    Note, the phone is on a tripod, so nothing is blocking the microphone at any point.
    I even went into the phone settings a few weeks ago and deleted the data, figuring it was a faulty file, and hoping it would "reinstall" or update to the latest version, but I don't believe it updated itself, and if it did, the problem remains (problem occurred a few hours ago today)
    Anybody else have this problem?
    04-04-2022 09:30 PM
  2. krisqz's Avatar
    Is it possible that you got a notification during recording? Just guessing here, though. Does it happen always when you're recording? At the same timestamp or is it random?
    05-25-2022 06:25 PM
  3. mustang7757's Avatar
    How far in recording does this happen?
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/as...community.html
    05-25-2022 09:25 PM
  1. Dtuck screen on battery save ko
    Last Post: 04-04-2022, 07:53 PM
  2. Replies: 2
    Last Post: 04-04-2022, 07:49 PM
  3. Waiting for connection when i send text
    Last Post: 04-04-2022, 01:52 PM
  4. Replies: 1
    Last Post: 04-04-2022, 10:55 AM
  5. can't access my settings app on Samsung core A03
    Last Post: 04-04-2022, 10:51 AM
