1. GazCBG's Avatar
    Hi,
    I have a Samsung S9 when I am on a call and press the speaker, I can, hear them but they can't hear me.
    They are not muted, and the mic works on voice recorder.
    I am using the Samsung Phone App that came with the phone.
    Where would I check to see if it been disabled in the settings somehow.
    Everything is updated.
    Regards,
    Gaz
    08-09-2022 07:27 AM
  2. mustang7757's Avatar
    Welcome to AC
    Check Samsung members app for diagnostics utilities to test speakers and mic , on newer Samsung its in device care but yours probably still in Samsung members app
    08-09-2022 11:00 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! It's possible the voice recorder uses a different mic than speakerphone, so it could still be due to a defective mic.
    Also, does this happen in Safe Mode? https://www.hardreset.info/devices/s...-s9/safe-mode/
    08-09-2022 11:37 AM
  4. Mr Bojangles1's Avatar
    Go to app info for your dialer app in your phone settings and under permissions make sure that permissions needed for it are not denied, like microphone.
    08-09-2022 03:31 PM
  5. GazCBG's Avatar
    Hi,
    Thanks for all the replies and welcomes
    It to have been a dirty mic 2, which is the top mic on the S9
    Which out found out when, I ran Samsung members app tests (Thanks mustang7757 didn't know that app was a thing).
    It would pick up on mic 1 ok, but mic 2 at the top, unless I shouted, so cleaned it out and it working better now.
    I made a test call and they could hear me ok.
    Regards,
    Gaz
    mustang7757 likes this.
    08-10-2022 02:24 AM
  6. mustang7757's Avatar
    Hi,
    Regards,
    Gaz
    Yeah pretty good diagnostic tool , glad you got it going
    08-10-2022 09:58 AM
  1. Static, popping, crackling sounds on my tablet.
    Last Post: 08-11-2022, 03:04 PM
  2. Google Photos on Pixel 6
    By ulnek in forum Google Pixel 6 & Pixel 6 Pro
    Last Post: 08-10-2022, 12:47 PM
  3. Apps seem to restart when switching. Samsung Tab A 2019 SM-T510
    By berntd in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 08-09-2022, 07:24 PM
  4. Why is my clock going off when it's not set?
    By theseawulf in forum Ask a Question
    Last Post: 08-09-2022, 11:43 AM
  5. One caller cannot hear me
    By Gem106 in forum Ask a Question
    Last Post: 08-09-2022, 04:33 AM
