1. Preach2k's Avatar
    If you are considering the S9 Plus, maybe you should look at the A8 Plus. Pretty much the same specs.
    https://m.gadgetsnow.com/compare-mob...galaxy-s9-plus
    01-21-2018 06:07 AM
  2. chanchan05's Avatar
    No. The performance is way different. We've already seen benchmarks of the processor used in the A8 and A8+ for. 2018 and they're both slower than the S7. If someone is considering the S9, they're likely already coming from phones with superior performance to the A8+.
    hasasimo likes this.
    01-21-2018 10:06 AM
  3. rushmore's Avatar
    Kind of like a Hyundai sedan is pretty much same as a Mercedes
    hasasimo and chanchan05 like this.
    01-22-2018 01:49 PM
  1. Replies: 2
    Last Post: 02-04-2018, 09:02 AM
  2. My note 5 battery is draining so fast after the latest nougat update
    By Android Central Question in forum Samsung Galaxy Note 5
    Last Post: 02-03-2018, 06:07 AM
  3. Aaking for back up password and anything i wrote not accepted
    Last Post: 01-22-2018, 02:24 AM
  4. Replies: 1
    Last Post: 01-21-2018, 03:52 AM
  5. My note 5 battery is draining so fast after the latest nougat update
    Last Post: 01-21-2018, 02:40 AM
