1. anon(27512)'s Avatar
    Anyone know if it will have one yet? Thanks.
    01-27-2018 09:25 PM
  2. Tim1954's Avatar
    The rumours have it that it will....
    anon(27512) likes this.
    01-27-2018 11:34 PM
  3. anon(27512)'s Avatar
    I just hope the trend of removing features from smartphones continues
    01-29-2018 08:47 PM
  4. Madscotsman's Avatar
    Yes it will support an SD card, the slot is the same as the S8 line, part of the SIM tray.
    01-30-2018 09:03 AM
  5. anon(27512)'s Avatar
    Hopefully the tray is made from aluminum like the frame and not that crappy flimsy plastic again.
    01-31-2018 12:30 AM
  6. Madscotsman's Avatar
    Be prepared for disappointment then.
    01-31-2018 12:26 PM
  7. jamezr's Avatar
    I switch between phones a lot by swapping sims. I have never had one break on me. Doesn't matter if they are plastic or metal....you don't need a lot of force to fit a sim into the slot then insert it back into the phone.
    02-01-2018 09:45 AM
  8. anon(27512)'s Avatar
    I do too. Still a flimsy tray. The phone is a grand. They can afford to give us aluminum instead of that thin plastic that breaks easily.
    02-02-2018 02:07 AM
  1. Weather card not showing
    By Rinsun in forum Moto G
    Last Post: 01-28-2018, 07:56 PM
  2. Sim card duplicates
    Last Post: 01-27-2018, 09:00 AM
  3. Sd card won't mount
    Last Post: 01-26-2018, 06:01 PM
  4. Can I use a Google play card on samsung galaxy apps?
    Last Post: 01-26-2018, 03:27 PM
  5. Does the ZTE N817 have a sim card.
    Last Post: 01-26-2018, 03:00 PM
