speedtrap63
I am using a S7E with Exynos. I do wish to have faster software updates, but at the same time I really like Samsung's hardware: screen, design, 3.5mm jack, wireless charging, etc.
I do notice S7E to stutter a bit after 1.5 years... didn't bother me much but definitely will enjoy lag free experience more. Redundant apps don't bother me. S9+ will have more than enough flash memory plus an SD extension
The only hardware Pixel 2 XL has on S9+ is probably the dual speaker.
Decisions decisions
Don't forget the Pixel camera is outstanding!
That said from your list of likes above sounds like you've made your decision. I don't think you can make a bad choice, but it seems like the S9+ might be best for you.
