I can't decide if I want to stick with my Note 8 or JUMP to the S9. Really, the only thing I see as an upgrade is the speakers. Help needed! Thanks in advance...
They using AKG tuned speakers. And it's not necessarily they used the same crappy earpiece as before. Apple and HTC both use the earpiece as the second speaker.Yes well, I think there is already a discussion about this on here.. I'll try and find it..
In any case, it really depends on the S pen. Do you want the pen or not?
Size not an issue? By the sounds the S9 isn't that much different from the S8...
Even though the speakers are supposed to be stereo etc, they just using the crappy earpiece as one speaker, so I wouldn't expect anything too starting in that department.
Unless you get the + model, you not getting all that much bang for your buck in my opinion, it just depends if you want that shiny new machine
I'll take it if it's an improvement over what we have now. The sound I get out of my Note 8 is about the only sub-par element of this handset. Sometimes I'll put this thing on speakerphone so the person next to me can join the conversation, but sometimes it's hard for them to hear even on max volume. Speaker is weak on this thing. Yes, my environment can be noisy, but other phones do much better.Well, whatever they use, I can't see any meaningful audio coming from a slot that's two mm wide and ten long...
True. I have the same issue. I love my note 8. I'll wait for the note 9 and jump on that day 1. Really have to learn to wait. But I do love new tech. But I know the note 9 will get all the new features plus some. So I'll try my best to wait.S9+ looks nice but I just can't justify leaving the note 8 for it.
My thoughts exactly!True. I have the same issue. I love my note 8. I'll wait for the note 9 and jump on that day 1. Really have to learn to wait. But I do love new tech. But I know the note 9 will get all the new features plus some. So I'll try my best to wait.
