    Really looking to get an S9 but I kinda really need an SD card slot too. Does the S9 have one?
    02-28-2018 11:49 PM
  2. Bla1ze's Avatar
    Sure is. You can have up to 400GB of SD storage.
    02-28-2018 11:51 PM
  3. piehans's Avatar
Name:	Screenshot 2018-03-01 01.51.02.png
    Just looking for an advice about buying the Galaxy S9.
    Expand the 64 GB with a SD card or just buy a 128 GB? The last option costs a bit more but a SD card is easy to use outside the phone. So what would you advice ?
    03-01-2018 07:37 AM
  4. anon(8453378)'s Avatar
    You are lucky. In the US, we only get the 64 GB versions. What is the price difference?
    03-01-2018 02:16 PM
  5. anon(8453378)'s Avatar
    Typically I put my photos and music on the SD card, so I wouldn't need more than the 64 GB version. It really depends on your usage.
    03-01-2018 02:19 PM
  1. Oreo update is a hoax
    By jeffmd in forum Samsung Galaxy S8 & S8+
    Last Post: 03-06-2018, 06:54 AM
  2. Anyone know where I can download the Samsung Galaxy S9 wallpapers?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 03-01-2018, 12:37 PM
  3. Is there a dedicated Bixby button on the S9?
    Last Post: 02-28-2018, 11:44 PM
