Activating unlocked S9+ on Verizon
sctiger
Active member
May 5, 2015
38
If I purchase an unlocked S9+ directly from Samsung, will activating it on Verizon be as simple as inserting the Sim card from my S8? Or, will I need to go to the Verizon store?
Jaycemiskel
Trusted Member
Jul 28, 2011
2,769
4
If the sim card is already activated, which it sounds like it is, then yes you'll be able to just insert the sim card and keep it moving.
Jan
