03-16-2019 06:38 AM
45 12
tools
  1. Quick Cal's Avatar
    So can you transfer the 4k video from the internal storage to the sd card using the phone.
    I'm planning a cross country trip on my Goldwing. I would hate to only be able to shoot only so much 4k footage. You would have to pick and choose what gets 4k,,,lol.
    03-06-2018 10:23 PM
  2. Gayle Lynn's Avatar
    Some USB-C if only there was 512GB or even 2TB.
    Samsung MUF-128DA2/WW USB Type-C 3.1 Flash Drive, 128 GB, Black - https://www.amazon.com/dp/B06XXQKRMZ...cUvbUpU6181884
    03-07-2018 07:50 AM
  3. Quick Cal's Avatar
    After recording in 4k for the 5 or 10 minute time limit, is the internal storage full?
    03-07-2018 08:24 AM
  4. Extremevl's Avatar
    Not at all
    The S9/S9+ come with 64GB of internal memory for the North American models which leaves around 55GB or so out the box (OS takes a little chunk).
    Based off this link (https://www.imore.com/how-shoot-trim...k-video-iphone) it shows that 4K@60FPS should take up around 400MB of memory per minute. This means you should be able to take slightly over 2 hours of 4K@60FPS video which would take up around 48GB - 52GB of memory.
    The 5 minute 4K@60FPS video recording limit is set by the software but there is no official word from Samsung or Qualcomm explaining why the S9/S9+ have this limit.
    The Qualcomm 845 chip has the raw power (https://www.qualcomm.com/products/sn...obile-platform) so I assume it's a power management or battery safety concern issue (phone heating up, etc)...
    03-07-2018 08:47 AM
  5. Quick Cal's Avatar
    Not at all
    Based off this link it shows that 4K@60FPS should take up around 400MB of memory per minute. This means you should be able to take slightly over 2 hours of 4K@60FPS video which would take up around 48GB - 52GB of memory.
    The 5 minute 4K@60FPS video recording limit is set by the software but there is no official word from Samsung or Qualcomm explaining why the S9/S9+ have this limit...
    Thank you for that.
    So after the 5 minutes will the camera just stop dead and you have to restart it. Or will it just make separate files automatically like some dslr's do and keep filming.
    03-07-2018 09:09 AM
  6. Extremevl's Avatar
    Thank you for that.
    I'm wondering that myself, none of the videos that I've seen show what happens at the 5 minute mark.
    I'm assuming it will stop the video and make you restart a new one because if it just makes a separate file but keeps recording then it wouldn't make sense to have the 5 minute limit in the first place.
    03-07-2018 09:17 AM
  7. Quick Cal's Avatar
    My son found something about why dslr's make separate files. It was due to the sd card. Something about fatfile or something. I can't find the info now.
    03-07-2018 09:22 AM
  8. Extremevl's Avatar
    Interesting, do you know if DSLR's have to stop recording once they hit that limit or do they just makes a new file instantly so you don't have to stop recording?
    03-07-2018 09:24 AM
  9. Quick Cal's Avatar
    From what I read they keep recording. When you download it i's mov1, mov2, mov3, and so on.
    Hmmm. I have dslr. Might be time for an experiment. Well scratch that. It doesn't shoot 4k,,,lol.
    03-07-2018 01:39 PM
  10. Extremevl's Avatar
    That wouldn't be too bad if you could keep recording but then I wonder why you couldn't just record continuously like the iPhone X...I'm thinking it's a heat issue.
    03-07-2018 02:09 PM
  11. Fred98TJ's Avatar
    Not at all
    And those files sizes are based on the fact that the iPhone 8, 8+ and X use HEVC formatting for 4k@60 files. Does the S9 have HEVC file format storage ? If not then the file sizes on the S9 are going to be a lot larger.
    03-07-2018 05:06 PM
  12. Extremevl's Avatar
    I don't know what formatting the S/S9+ uses but Phone Arena says -
    "not to mention the amount of internal memory the footage will occupy at that length anyway, even in the high-efficiency video format that the S9 recordings support"
    https://www.phonearena.com/news/Gala...ormat_id102945
    I don't know if that means they use the HEVC file format storage or something similar?
    03-07-2018 07:29 PM
  13. Fred98TJ's Avatar
    After poking around some it appears that the S9 (and Plus) use HEVC (H.265) storage format, which is probably a given when recording at 4k@69fps. With the “old” H.264 format the file sizes would be massive.
    03-08-2018 08:05 PM
  14. Extremevl's Avatar
    Nice, thank you!
    03-08-2018 08:41 PM
  15. rahool360's Avatar
    oh thats a bumper ...limiting time for recording videos!!!
    03-08-2018 09:45 PM
  16. CKwik240's Avatar
    I'm thinking it could be to help with post processing. I edit some 4K videos occasionally on my desktop (3.2 ghz core i7, 12 gb ram, geforce gtx 1070 video card and it still takes a couple of hours to process long videos (took nearly 24 hours before I upgraded my antiquated workstation video card). I can't even imagine trying to do that on a phone.
    03-09-2018 01:39 AM
  17. Fred98TJ's Avatar
    Also the iPhone X has a dedicated ISP (hardware) for image processing, noise reduction, etc. I think maybe the Samsung’s limit has to do with a combo of heating and the inability to process the images (4k@60) fast enough so its buffer slowly fills and maybe even a inability to write the data fast enough to memory.
    03-09-2018 03:43 AM
  18. Chadwick Carlisle's Avatar
    DSLRs cut footage because the fat32 sd file format can only produce 4gb files or lower. The S9+ (as I can speak on the one that I own) CAN and does write to external sd cards. I have a 256 EVO so it is more than fast enough. Ill try with a slower card to see if it creates a limitation.
    As for the 5 min limit, as a filmmaker and photographer, this is MORE than enough to shoot scenes to be edited for film or television or web. If youre looking for a longer option for say a wedding or a dissertation, use a lower resolution as it will increase continuous recording time... for instance FHD 1920x1080 doesnt give me a limitation.
    10-19-2018 08:10 PM
  19. Dominick_A99's Avatar
    My unlocked Samsung Galaxy S9 plus doesn't show me any options at all to go to 4k idk why because I been trying the past few days. I need someone help with this please and thank you!
    03-16-2019 01:23 AM
  20. lucianus_luciferus's Avatar
    Open camera, go to settings, rear video resolution
    03-16-2019 06:38 AM
45 12
  1. Replies: 2
    Last Post: 04-03-2018, 12:44 PM
  2. S9 Plus - Locked or Unlocked?
    By louzer in forum Samsung Galaxy S9 & S9+
    Last Post: 03-04-2018, 02:52 PM
  3. All US Samsung Galaxy S9/S9+ Band Frequencies!
    By Extremevl in forum Samsung Galaxy S9 & S9+
    Last Post: 03-03-2018, 06:05 PM
  4. I cannot update my J7 Prime and the device status is "Custom"
    Last Post: 03-02-2018, 11:58 PM
  5. HTC U11 ATT and Telcel compatibility in Mexico
    By Sterling147 in forum HTC U11
    Last Post: 03-02-2018, 10:48 PM
